NB vs WB
Marek0086
NB vs WB
Post by Marek0086 »
Is it true that NB and WB sensors are the same... and its just the controller circuitry thats different?
malcom2073
Re: NB vs WB
Post by malcom2073 »
Marek0086
Re: NB vs WB
Post by Marek0086 »
What are your thoughts on "tuning devices" that use a narrow band sensor?. Can a NB be "offset" to measure between, say, 12.0:1 and 13.0:1 ??
Re: NB vs WB
NB i useless except for keeping catalytic converters happy by oscillating them back and forth past stoich...
malcom2073
Re: NB vs WB
Marek0086 wrote:What are your thoughts on "tuning devices" that use a narrow band sensor?. Can a NB be "offset" to measure between, say, 12.0:1 and 13.0:1 ??
Nope. They're pretty much only useful for an ECU (typically stock, aftermarket closed loop use should WB anyway) to maintain a stoich AFR during normal (not WOT/idle) closed loop operations.
Marek0086
Re: NB vs WB
Post by Marek0086 »
What are your thoughts on "tuning devices" that use NB sensors?
Re: NB vs WB
malcom2073 wrote:Nope. They're pretty much only useful for an ECU (typically stock, aftermarket closed loop use should WB anyway) to maintain a stoich AFR during normal (not WOT/idle) closed loop operations.
That's not really true. They don't maintain stoich, they intentionally oscillate either side of stoich to make the catalytic converter work optimally. If they did want to maintain stoich, they couldn't do that either, swinging side to side is all they can do.
Marek0086
Re: NB vs WB
Post by Marek0086 »
I don't think thats true. The only reason they swing back and forth is because of the OEM ECU, isn't it?. Im pretty sure they could stabilize an output if the AFR was stable at stoich.
Re: NB vs WB
Then you clearly don't understand how narrowbands work. Sorry I couldn't explain it to you.
Marek0086
Re: NB vs WB
Post by Marek0086 »
I have some idea. Why would the output swing back and forth... rich and lean... if the AFR is constant??
Locked
