flat4, you're on the wrong hash, please get on the right hash and test first.
git reset --hard 85e32661d6281c312c8
FreeEMS_Loader
Re: FreeEMS_Loader
Re: FreeEMS_Loader
I've got a problem using the FreeLoader app. http://issues.freeems.org/view.php?id=866
Pulled out all of my hair allready and am about to start on someone elses...
Reason: Remove material from issue.
Re: FreeEMS_Loader
just tried to build this (fresh git pull) and it doesn't make
snip here --> http://pastebin.com/SJXnk0em
Re: FreeEMS_Loader
This is your fault :-)
RTFM or RTFREADME
But also:
http://mikesshop.net/EMStudio/
Get the debs and run from binary like a good tester, please.
RTFM or RTFREADME
But also:
Re: FreeEMS_Loader
lol yep
RTFREADME LOL
builds ok now, thanks!
will use bin's in future
RTFREADME LOL
Re: FreeEMS_Loader
Clear out the from-src ones and use bins now, please.
Re: FreeEMS_Loader
Hello All,
I'm having a problem with FreeEMS Loader crashing when trying to load a file to my Jaguar board.
I have tried FreeEMS Loader on Windows XP and Win7 x64 , same result. The .s19 file is from the /dev branch,
checksum is OK.
TIA,
Dave.
checksum is OK.
TIA,
Dave.
Re: FreeEMS_Loader
Did you get it from Mike's server: http://mikesshop.net/EMStudio/ ?
If so, there are some other options:
1) Run Linux and use it there
2) Run a Linux VM and use it there
3) Either of the above, but use MTXLoader from MegaTunix instead. I know some users use and prefer this over the "FreeEMS loader".
4) Use either of the above, but try Mike's QT loader, which is new and lightly tested, but probably better
This app needs to be retired and replaced with something that works and is easily available for all platforms.
