View unanswered posts | View active topics It is currently Wed Apr 24, 2019 3:03 pm
Reply to topic  [ 88 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
FreeEMS_Loader
flat4, you're on the wrong hash, please get on the right hash and test first.
git reset --hard 85e32661d6281c312c8
Fri Oct 12, 2012 5:26 pm
I've got a problem using the FreeLoader app. http://issues.freeems.org/view.php?id=866
Pulled out all of my hair allready and am about to start on someone elses...;)
Remove material from issue.
Thu Oct 03, 2013 11:26 am
just tried to build this (fresh git pull) and it doesn't make :-P
snip here --> http://pastebin.com/SJXnk0em
Mon Dec 16, 2013 12:59 pm
This is your fault :-)
RTFM or RTFREADME
But also:
http://mikesshop.net/EMStudio/
Get the debs and run from binary like a good tester, please.
Mon Dec 16, 2013 1:27 pm
lol yep
RTFREADME LOL
builds ok now, thanks!
will use bin's in future :-)
Mon Dec 16, 2013 2:14 pm
Clear out the from-src ones and use bins now, please.
Mon Dec 16, 2013 8:25 pm
Hello All,
I'm having a problem with FreeEMS Loader crashing when trying to load a file to my Jaguar board.
I have tried FreeEMS Loader on Windows XP and Win7 x64 , same result. The .s19 file is from the /dev branch,
checksum is OK.
TIA,
Dave.
Sat Aug 16, 2014 5:20 pm
Did you get it from Mike's server: http://mikesshop.net/EMStudio/ ?
If so, there are some other options:
1) Run Linux and use it there
2) Run a Linux VM and use it there
3) Either of the above, but use MTXLoader from MegaTunix instead. I know some users use and prefer this over the "FreeEMS loader".
4) Use either of the above, but try Mike's QT loader, which is new and lightly tested, but probably better
This app needs to be retired and replaced with something that works and is easily available for all platforms.
Sat Aug 16, 2014 11:44 pm
