Sounds like some sort of communications error. Can you send me your debug logs? Upload them to dropbox, or email them (malcom2073@gmail.com) They should be in your home folder (C:\Users\yourname\EMStudio\applogs), just send me everything in that folder?E4ODnut wrote:If I open EMS Studio it says it is connected on Com3 but nothing happens immediately. After about 30 seconds after connection there is a short flash of the TX LED on Jaguar. Nothing changes. After about another 30 seconds there is another short flash on the TC LED and EMS Studio starts interrogating Jaguar, both TX and RX LEDs will flash in turn. Only once did the interrogation complete. Ever since then any attempt has failed and there is no live data. CEL LED keeps blinking merrily on.
E4ODnut wrote:I don't see any bench test tabs on EM Studio.
What hash are you using? Are you using the latest "dev" from the build server? You should be using 12f3153a05d67d00b0086ecf553699bb8d8f2920, which is currently listed under dev on the build server.
See aboveFred wrote:The latest EMStudio should have a BenchTest wizard in the wizards menu IIRC. Hash mike? Available on CI?
