I was mainly having a bit of a stir
I do hope to have a go of it with the 36-1 encoder wheel and get DFI working.
The alpha code with 4 fuel channels has me interested because at the moment starting, idling & light throttle isn't the best. Mostly due to having a big single plain manifold on a mild v8, the semi-sequential would help improve that I think. As a "precaution"
I've also started building another engine with a stroker-crank (will improve bottom end torque, effficiency & intake runner velocities) as well as heads and cam that better match the EFI manifold & throttlebody.
Should be good for testing a FreeEMS ECU on??
