Aaron,
Still no luck with the dowload on github.
Sue is going to need to need a copy if she is going to help.  Any thoughts?
Mark
						How To Install Python, Libs and FreeEMS-Tuner
- sry_not4sale
Re: How To Install Python, Libs and FreeEMS-Tuner
Really? That's shocking!
Here is a temporary link in case github won't work for her either
http://spastk.com/files/srynot4sale-fre ... 07a.tar.gz
Ok, the new link worked.
Now for the really stupid question, how do I run it? All the stuff on the list are doanloaded and install butI don't seem to have anything that regonizes this file type?
- sry_not4sale
Did you run the Python MSI installer?
http://www.python.org/download/releases/2.6/
That should associate python (.py) files with Python, and you should be able to double-click the main.py file and have it boot up.
Yes, several times now.
The tuner came in as a xxxx.gz is that correct? PythonWin does not recognize that extension?
- sry_not4sale
Ah, apologies. The *.tar.gz file is a compressed archive - much like a *.zip file. You need to extract it using a compression program - e.g. http://www.7-zip.org/
- sry_not4sale
I am in the process or merging this thread with the Tuner Installation wiki page, and then we can link people directly to that for now on.
Maybe I should set up a proper windows installer for the app sooner rather than later.
Got it. Thank you!sry_not4sale wrote:Ah, apologies. The *.tar.gz file is a compressed archive - much like a *.zip file. You need to extract it using a compression program - e.g. http://www.7-zip.org/
You Linux virgins, how do you do it   There is so much you can do in Linux that you can't do in MS land. I couldn't help but get dragged through it. I now wonder why I keep an XP box in my system.
 There is so much you can do in Linux that you can't do in MS land. I couldn't help but get dragged through it. I now wonder why I keep an XP box in my system.Re: How To Install Python, Libs and FreeEMS-Tuner
Like living in the nothing plays with anything else without finding 1/2 dozen other things....no thanks. I'm a big fan of plug and playjharvey wrote:There is so much you can do in Linux that you can't do in MS land.
