Re: freeEMS_1.0 rev A KICAD
I think I understand what you are looking for. Here I go.
My first post to pass information around was these pictures.
The top page is here http://i324.photobucket.com/albums/k352 ... MS_pg1.gif
The power reg is here http://i324.photobucket.com/albums/k352 ... S_pg30.gif
The injector supply is here http://i324.photobucket.com/albums/k352 ... S_pg21.gif
The ADC filter is here http://i324.photobucket.com/albums/k352 ... MS_pg7.gif
Then I attached this
http://www.diyefi.org/forum/download/file.php?id=23
Then these
http://www.diyefi.org/forum/download/file.php?id=31
http://www.diyefi.org/forum/download/file.php?id=30
Then
http://www.diyefi.org/forum/download/file.php?id=33
http://www.diyefi.org/forum/download/file.php?id=32
then
http://www.diyefi.org/forum/download/file.php?id=36
http://www.diyefi.org/forum/download/file.php?id=35
then
http://www.diyefi.org/forum/download/file.php?id=38
http://www.diyefi.org/forum/download/file.php?id=37
then
http://www.diyefi.org/forum/download/file.php?id=40
http://www.diyefi.org/forum/download/file.php?id=39
then
http://www.diyefi.org/forum/download/file.php?id=50
http://www.diyefi.org/forum/download/file.php?id=49
then they come from Sourceforge
http://sourceforge.net/project/showfile ... _id=618983
Do you need the Sourceforge links? I think those might be easier obtained from SF.
Also I see I posted the history at SF as well, so perhaps we should just use the SF for the GIT history.
Then these
Then
then
then
then
then
Cheers!
Question time :
I've setup the project and am ready to start pushing revisions, but not sure about which files are required and which are not.
Thanks!
EDIT : PDF variants are not required for the source copy, they are an output file really. I'll probably split most of the docs out of the firmware source at some point.
Question time :
- I don't have 2, only 1 and 3 - 9, any idea where 2 is?
- I see lots of .bak and .xyz~ files, which are backup files?
Thanks!
Unzipped :
Tilda suffixes removed :
Bak suffixes removed :
I would expect that the last one is what I want to commit?
Cheers,
fred@rwdlsd [07:05:45]:freeems-hw-jharvey$ l
total 236
-rw-rw-r-- 1 fred fred 12943 2008-07-29 09:07 freeEMS_1.bak
-rw-rw-r-- 1 fred fred 5773 2008-07-05 22:58 freeEMS_1.cache
-rw-rw-r-- 1 fred fred 2146 2008-07-05 22:36 freeEMS_1.cache.bak
-rw-rw-r-- 1 fred fred 569 2008-07-29 09:07 freeEMS_1.cache.bck
-rw-rw-r-- 1 fred fred 73 2008-07-05 22:55 freeEMS_1.cache.dcm
-rw-rw-r-- 1 fred fred 6171 2008-07-29 09:07 freeEMS_1.cache.lib
-rw-rw-r-- 1 fred fred 73 2008-07-05 22:58 freeEMS_1.dcm
-rw-rw-r-- 1 fred fred 925 2008-07-06 02:47 freeEMS_1.pro
-rw-rw-r-- 1 fred fred 12943 2008-07-29 09:07 freeEMS_1.sch
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_BAT_condition.bak
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_BAT_condition.sch
-rw-rw-r-- 1 fred fred 474 2008-07-06 01:36 freeEMS_BAT_condition.sch~
-rw-rw-r-- 1 fred fred 2908 2008-07-29 09:07 freeEMS_CPU.bak
-rw-rw-r-- 1 fred fred 2908 2008-07-29 09:07 freeEMS_CPU.sch
-rw-rw-r-- 1 fred fred 1904 2008-07-05 23:42 freeEMS_CPU.sch~
-rw-rw-r-- 1 fred fred 615 2008-07-29 09:07 freeEMS_ignition.bak
-rw-rw-r-- 1 fred fred 615 2008-07-29 09:07 freeEMS_ignition.sch
-rw-rw-r-- 1 fred fred 5323 2008-07-29 09:07 freeEMS_injector_drive.bak
-rw-rw-r-- 1 fred fred 4888 2008-07-28 07:26 #freeEMS_injector_drive.sch#
-rw-rw-r-- 1 fred fred 5323 2008-07-29 09:07 freeEMS_injector_drive.sch
-rw-rw-r-- 1 fred fred 4714 2008-07-28 07:22 freeEMS_injector_drive.sch~
-rw-rw-r-- 1 fred fred 1916 2008-07-29 09:07 freeEMS_input_protection_an.bak
-rw-rw-r-- 1 fred fred 1916 2008-07-29 09:07 freeEMS_input_protection_an.sch
-rw-rw-r-- 1 fred fred 452 2008-07-06 02:04 freeEMS_input_protection_an.sch~
-rw-rw-r-- 1 fred fred 1510 2008-07-29 09:07 freeEMS_input_protection_dig.bak
-rw-rw-r-- 1 fred fred 1510 2008-07-29 09:07 freeEMS_input_protection_dig.sch
-rw-rw-r-- 1 fred fred 452 2008-07-06 02:04 freeEMS_input_protection_dig.sch~
-rw-rw-r-- 1 fred fred 2867 2008-07-29 00:31 freeEMS_lib.bak
-rw-rw-r-- 1 fred fred 174 2008-07-29 00:31 freeEMS_lib.bck
-rw-rw-r-- 1 fred fred 174 2008-07-29 00:36 freeEMS_lib.dcm
-rw-rw-r-- 1 fred fred 2863 2008-07-29 00:36 freeEMS_lib.lib
-rw-rw-r-- 1 fred fred 2061 2008-07-05 23:20 freeEMS_lib.lib~
-rw-rw-r-- 1 fred fred 2566 2008-07-29 09:07 freeEMS_MAP_input.bak
-rw-rw-r-- 1 fred fred 2566 2008-07-29 09:07 freeEMS_MAP_input.sch
-rw-rw-r-- 1 fred fred 474 2008-07-06 01:36 freeEMS_MAP_input.sch~
-rw-rw-r-- 1 fred fred 6000 2008-07-29 09:07 freeEMS_power_reg.bak
-rw-rw-r-- 1 fred fred 6000 2008-07-29 09:07 freeEMS_power_reg.sch
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_RPM_input.bak
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_RPM_input.sch
-rw-rw-r-- 1 fred fred 474 2008-07-06 01:36 freeEMS_RPM_input.sch~
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_thermistor_resistor_input.bak
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_thermistor_resistor_input.sch
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_TPS_input.bak
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_TPS_input.sch
-rw-rw-r-- 1 fred fred 474 2008-07-06 01:36 freeEMS_TPS_input.sch~Code: Select all
fred@rwdlsd [06:34:23]:freeems-hw-jharvey$ l
total 196
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_TPS_input.schCode: Select all
fred@rwdlsd [07:04:59]:freeems-hw-jharvey$ l
total 120
-rw-rw-r-- 1 fred fred 602 2008-07-29 09:07 freeEMS_TPS_input.schCheers,
Nearly the last one is what you want to commit. The one with #'s is also a bak file.
You might also want to include the template folder / files, as well as the script file.
Ah yes, missed that one :-)
There were no templates or scripts in the version 1 zip as far as I could tell. If they appear in later version then they will get commited at that point in sequence.
I'll get started now :-)
Cheers,
Cheers,
Jared, are .bck files back as well??? :-p Do you really need 3 types LOL...
Man I love git! It's watching you son, no escaping the truth now ;-)
Looks to be a lot of duplication in there, is there such a concept as #include for the injector_drive3.sch stuff etc?
fred@rwdlsd [12:37:31]:design$ git commit -a
[master 5bb01ed] Revision 8 = major changes from file : freeEMS_1.0_A.08.zip
80 files changed, 7941 insertions(+), 1430 deletions(-)
create mode 100644 design/$savepcb.000
create mode 100644 design/$savepcb.brd
rename design/{freeEMS_BAT_condition.sch => BAT_condition.sch} (95%)
rename design/{freeEMS_CPU.sch => CPU.sch} (60%)
copy design/{freeEMS_MAP_input.sch => MAP_input1.sch} (98%)
copy design/{freeEMS_MAP_input.sch => MAP_input2.sch} (98%)
rename design/{freeEMS_O2_input.sch => O2_input.sch} (90%)
create mode 100644 design/PCB-modules/R4-SM0805.emp
create mode 100644 design/PCB-modules/SM0805.emp
create mode 100644 design/PCB-modules/free_EMS.mdc
create mode 100644 design/PCB-modules/free_EMS.mod
create mode 100644 design/RPM_input1.sch
create mode 100644 design/RPM_input2.sch
rename design/{freeEMS_TPS_input.sch => TPS_input.sch} (95%)
copy design/{freeEMS_input_protection_an.sch => an_protect1.sch} (90%)
copy design/{freeEMS_input_protection_an.sch => an_protect2.sch} (90%)
copy design/{freeEMS_input_protection_an.sch => an_protect3.sch} (90%)
copy design/{freeEMS_input_protection_an.sch => an_protect4.sch} (90%)
rewrite design/convert.sh (93%)
delete mode 100644 design/digi_protect.sch
create mode 100644 design/digi_protect_I1.sch
create mode 100644 design/digi_protect_I2.sch
create mode 100644 design/digi_protect_I3.sch
create mode 100644 design/digi_protect_I4.sch
create mode 100644 design/digi_protect_I5.sch
create mode 100644 design/digi_protect_I6.sch
create mode 100644 design/digi_protect_fuel.sch
create mode 100644 design/digi_protect_misc1.sch
create mode 100644 design/digi_protect_misc2.sch
create mode 100644 design/digi_protect_rpm1.sch
create mode 100644 design/digi_protect_rpm2.sch
delete mode 100644 design/freeEMS_1.cache
delete mode 100644 design/freeEMS_1.cache.dcm
delete mode 100644 design/freeEMS_RPM_input.sch
delete mode 100644 design/freeEMS_input_protection_dig.sch
copy design/{freeEMS_general_drive.sch => general_drive1.sch} (98%)
copy design/{freeEMS_general_drive.sch => general_drive2.sch} (98%)
copy design/{freeEMS_general_drive.sch => general_drive_fuel.sch} (98%)
copy design/{freeEMS_ignition.sch => ignition1.sch} (97%)
copy design/{freeEMS_ignition.sch => ignition2.sch} (97%)
copy design/{freeEMS_ignition.sch => ignition3.sch} (97%)
copy design/{freeEMS_ignition.sch => ignition4.sch} (97%)
copy design/{freeEMS_ignition.sch => ignition5.sch} (97%)
copy design/{freeEMS_ignition.sch => ignition6.sch} (97%)
copy design/{freeEMS_injector_drive.sch => injector_drive1.sch} (99%)
copy design/{freeEMS_injector_drive.sch => injector_drive2.sch} (99%)
copy design/{freeEMS_injector_drive.sch => injector_drive3.sch} (99%)
copy design/{freeEMS_injector_drive.sch => injector_drive4.sch} (99%)
copy design/{freeEMS_injector_drive.sch => injector_drive5.sch} (99%)
copy design/{freeEMS_injector_drive.sch => injector_drive6.sch} (99%)
copy design/{freeEMS_power_reg.sch => power_reg1.sch} (99%)
copy design/{freeEMS_power_reg.sch => power_reg2.sch} (99%)
create mode 100644 design/spice/fet test.dat
create mode 100644 design/spice/fet test.dpl
create mode 100644 design/spice/fet test.sch
create mode 100644 design/spice/inductor_test_jig.dpl
create mode 100644 design/spice/inductor_test_jig.sch
create mode 100644 design/spice/injector.dpl
create mode 100644 design/spice/injector.sch
create mode 100644 design/spice/injector_Csnub.dpl
create mode 100644 design/spice/injector_Csnub.sch
create mode 100644 design/spice/injector_Dsnub.dpl
create mode 100644 design/spice/injector_Dsnub.sch
rename design/{freeEMS_MAP_input.sch => templates/MAP_input.sch} (98%)
create mode 100644 design/templates/RPM_input.sch
rename design/{freeEMS_input_protection_an.sch => templates/an_protect.sch} (90%)
create mode 100644 design/templates/digi_protect.sch
rename design/{freeEMS_general_drive.sch => templates/general_drive.sch} (98%)
rename design/{freeEMS_ignition.sch => templates/ignition.sch} (98%)
rename design/{freeEMS_injector_drive.sch => templates/injector_drive.sch} (99%)
rename design/{freeEMS_power_reg.sch => templates/power_reg.sch} (99%)
copy design/{freeEMS_thermistor_resistor_input.sch => templates/thermistor_resistor_input.sch} (97%)
copy design/{freeEMS_thermistor_resistor_input.sch => thermistor_resistor_input1.sch} (96%)
rename design/{freeEMS_thermistor_resistor_input.sch => thermistor_resistor_input2.sch} (96%)
Now this is efficient! :
Full history and current working copy inside 3.5 meg, could probably have been smaller without the .bck files ;-)
Fork at will! :-)
http://github.com/fredcooke/freeems-hw- ... ree/master
Best to fork on github to your account and work on it from there pushing back up to your copy as you please. People can grab updates of various parts as they see fit with git cherry pick.
Enjoy!
fred@rwdlsd [12:59:12]:freeems-hw-jharvey$ du -hs .git/
2.4M .git/
fred@rwdlsd [12:59:16]:freeems-hw-jharvey$ du -hs .
3.5M .
Fork at will! :-)
Enjoy!
I believe the .bck is KICAD backing stuff up. The ~ files are emacs backing things up, and the # files are something else backing things up. Perhaps that was joe, or nano. I really just didn't pay much attention to them. The $ files, may also be backups. Not sure what would be making them.
I guess now I'll have to figure out how to fork, and check out a copy of that repo.
Yeah - the .bak's aren't good for much, just make things bigger.
Did we agree on a version? Since not everything handles version changes well in KiCAD, I'd suggest somehow tagging the files with the desired version of KiCAD to use.
