Oops my bad, I had included it with 0.0.17, but for got to add that to the zip file. I think it's best to not have multiple copies of almost the exact same file out there, so I'm not planning on adding it to the SF zip. I just uploaded it to the below link, and I'll try to remember to include it in the next zip version.Fred wrote:Mate, Abe just pointed out that the index is boring as hell. I just googled and found it can be improved quite easily. I'd like to see that stuff and the config you use to generate it included in the release so that it's JUST a matter of generating it for you
http://freeems.sourceforge.net/doxygen/ ... 8/Doxyfile
This file is made entirely from the Doxywizard. For each release my plan it to copy the old Doxyfile from the previous release, to the new, then update the location(s) and rerun doxygen. The generated folder and the Doxyfile get compressed. I simply forgot to select the Doxyfile when I told it to compress.
That self documenting stuff it nice, certainly no complaints from me about doing it. However perhaps that should be a little lower priority, with making her go higher on the list.Fred wrote:Also, I can update the existing docs to work a lot better with it...
Thanks for the jump off point, I should be able to look into that better in a day or two.Fred wrote:Have a look here for the index stuff :
http://lhcb-release-area.web.cern.ch/LH ... MainPage.h
and here in general :
http://lhcb-comp.web.cern.ch/lhcb-comp/ ... oxygen.htm
Let's make this as awesome as humanly possible
