Anyone have any ideas on why I cant seem to get freeEMS loaded into flash?? Log Attached
bash freeEMSloader.bash /dev/ttyS0 freeems-v0.0.7.s19
Welcome to the FreeEMS firmware loader
This program is released under the GPL V3
Please see
http://www.gnu.org/licenses/ for details
This version is for mc9s12xdp512 based FreeEMS's
Do you have a mc9s12xdp512 based FreeEMS? [ yes | quit ]
yes
Checking configuration and arguments...
Everything looks good!
Erase the flash on your FreeEMS? (This is necessary to load new firmware) [ yes | abort ]
yes
Erasing the FreeEMS flash without verification...
hcs12mem: Freescale S12 MCU memory loader V1.4.1 (C) 2005-2007 Michal Konieczny <
mk@cml.mfk.net.pl>
target info <single chip MC9S12Dx512 MCU>
target mcu <MC9S12D512> family <S12X>
SM serial port </dev/ttyS0> baud rate <115200 bps>
SM target connected
SM version <2.02> date <2004-07-23>
S12X part id <0xC410> family <XD> memory <512kB> mask <1.0>
S12X part security <unsecured> backdoor key <enabled>
S12X register space <2kB> address range <0x0000-0x07FF>
S12X RAM size <14kB> space <12kB> address range <0x1000-0x3FFF>
S12X FLASH module <FTS512K4> size <512kB> state <enabled> ROMHM <no>
S12X FLASH block <0> protection all <off> high area <2kB> low area <off>
S12X FLASH block <1> protection all <off> high area <2kB> low area <off>
S12X FLASH block <2> protection all <off> high area <2kB> low area <off>
S12X FLASH block <3> protection all <off> high area <2kB> low area <off>
FLASH erase: wait ...
FLASH erase: memory erased
Erasing flash was successful!
Load the firmware to your FreeEMS? [ yes | abort ]
yes
Loading freeems-v0.0.7.s19 to FreeEMS flash without verification...
mk@cml.mfk.net.pl>
SM target connected
FLASH write: image file <freeems-v0.0.7.s19>
FLASH write: image info <freeems-v0.0.7.s19> entry <0xC000>
FLASH write: address range <0xC000-0xCC53> size <0x0C54>
FLASH write: address range <0xF710-0xF7FF> size <0x00F0>
FLASH write: image [ ]
error: timeout - no connection with target
Firmware load failed! exiting...
localhost bin #
