97 LT1 Turbo/MS project
- SleepyKeys
Re: 97 LT1 Turbo/MS project
Nope, just flipped one. I used two passenger side manifolds.
You snooze, you lose!
So, one facing foreward and one facing back? If that is the case I would guess that the drivers is facing foreward and maybe the exhaust from the passenger side comes around the back of the engine and dumps into the other manifold or joins it by a y-pipe very close to the turbine inlet.
I sure would like to get your car on a hoist and just look around!
Thanks for the continuing info by the way.
- SleepyKeys
Correct. The car is 200 miles away. When I get it back I'll take some more detailed pics.
That would be awesome! I am sure your y-pipe strategy is going to be difficult to get good photos of, but any and all are gladly appreciated.
I don't suppose you have the specs on the turbo you are using or link a page with the specs?
- SleepyKeys
Its just a T70, p-trim wheel. .70/ar compressor .96/ar turbine. Fred posted the flow map in the thread about my car.
-sean
-sean
do you know the actual wheel measurements though?
- SleepyKeys
Turbine Wheel:
-Exducer Diameter: 2.53"
-Mayor Diameter: 2.91"
Compressor Wheel:
-Exducer Diameter: 2.72"
-Mayor Diameter: 3.58"
Turbine Housing:
-A/R: .96
-Type: Undivided
-Discharge: V-Band
-inlet: T4
Compressor housing:
-A/R: .70
-Air Inlet: 4.00"
Compressor Wheel:
Turbine Housing:
-A/R: .96
-Type: Undivided
-Discharge: V-Band
-inlet: T4
Compressor housing:
-A/R: .70
-Air Inlet: 4.00"
Thank you. I want to compare yours to mine...unfortunately I won't be able to measure mine for a few days.
that could be misinterpreted to sound bad...haha
![Sad :(](./images/smilies/icon_e_sad.gif)
- SleepyKeys
