T56 trans
Home brew T70 Turbo setup
Comments/Suggestions welcome
-sean
Originally I wanted a T76, but I ran across a good deal on a T70 and did a little investigation and came to the same conclusion you did "impressive little bastard". Plus I figured less lag than the 76, so it would make it more street friendly. So I got it and built my setup around that. I have the 10# spring in the waste-gate right now. I'll hookup the boost solenoid in the next few weeks.Fred wrote:God damn! What do they rev to? Thats meanHome brew turbo setups FTW
That T70 flows 25% more than my he351cw! you could be making 700 - 850 crank hp from that, have you dynoed it? How much boost are you pushing?
Here is where I am on my compressor map (estimated) :
http://i50.photobucket.com/albums/f323/ ... rankHP.jpg
And roughly where I hope to be when I up the boost to the whole 27psi (500 - 550 crank hp) :
And a fake dyno based on fuel flow from duty cycle in my logs :
http://i50.photobucket.com/albums/f323/ ... /power.jpg
Have you got more detailed pics of the setup at all, or videos of you misbehaving in it? Must blow a few hondas away
lol maybe a little, but broken indeed, I don't like it either, but thats how I communicate with my fellow yanks.Fred wrote:This may seem somewhat selfish and narrow minded, but I ask anyone posting imperial figures to post metric with them. lb/hr means nothing to me at allthough, I can look it up. Degrees F is even worse (no direct ratio comparision...).
Imperial is a broken old system, good for measuring wheels and manhood and little else![]()
At what brake specific? I haven't checked DC since the MS install, but with the factory ecu and my procharger making 9 psi it was at 73% dc. I read that my Bosch injectors should only be used to 85% dc, that statement may however be hear say.Fred wrote: Google tells me 55lb/hr = 550cc/min = 110hp each = 880hp total for a V8. I think using larger ones would be extreme overkill for your 750 goals. What are your current duty cycles looking like?
