Fred wrote:
IIRC this is just going on a B230F redblock at which point IAC is your only accessory, right?
Actually that's almost definitely true, yes. Partly I'd forgotten that the fan, fuel pump, etc, would be driven by HSD/LSD. Partly, I'm also harboring delusions of getting an rpm signal to an Arduino so I can drive the stock Amazon speedo cylinder with a stepper motor and an L298N. It's a distraction I should ignore for now.
Fred wrote:
What's your time frame?
I read your recent post on turbobricks and felt like it should be me asking you that question
A couple of months would be great, a few months would be OK. There are lots of cobbled roads around here that I'd love to be losing traction on by June/July.
Fred wrote:
Some board photos might be a good idea, too? I see you used to use photobucket
Yes I was one of the many people upon whose chips Photobucket pissed.
Fred wrote:
might pay to log in and rehost them and get me to fix your other thread up.
Done. They're
here, the following three are the ones left from my build thread. I don't seem to have the photos I took of the CAS-distributor hack job I wrote about in that other thread, and they're no longer visible on Photobucket.
Car:
https://ibb.co/mP4JVnTPS:
https://ibb.co/mbEwGSIAT:
https://ibb.co/ixMXqnI'll get board and hopefully more car photos soon too.
Shopping list question:Will these be OK to use with the Jaguar? The only mention of them on the site I could find was
here.
60lb/630cc Siemens Deka injectors. fi114961.
(Can't find a proper tech sheet).
Quote:
Specifications:
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
Connector: Bosch EV6
Series: DEKA 4 ( DEKA IV )
Orifice Type: Multi-orifice
Spray Pattern: 30 Degree Spray Cone
Thanks. I want to spend some money
