View unanswered posts | View active topics It is currently Sat Feb 16, 2019 4:13 pm
Reply to topic  [ 113 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12  Next
And this afternoon I picked up a set of four matching wheels from a freight depo for 100 nzd + 80 shipping.
And tonight I found, bought, picked up, paid for, and brought home a pair of reasonable tyres to go on a pair of them.
The tyres on them were the wrong size, which might have been OK, except for the 4wd system.
https://twitter.com/FredCookeNZ/status/ ... 2430586880
https://twitter.com/FredCookeNZ/status/ ... 1195584512
Fri Oct 06, 2017 10:39 am
And today's efforts on the same topic:
1) Stripped flat and good-but-wrong tyres off
2) Fitted cheap used tyres on
3) Balanced with used tyres
4) Carted home and swapped around
5) Acid cleaned with NZ made Luxxio Agent X wheel cleaner
6) Sponge bath for the rest of the entire thing
7) Out for lunch and social visit
8) Dragging the Volvo caravan around with it
Pics:
https://twitter.com/FredCookeNZ/status/ ... 4015777792
https://twitter.com/FredCookeNZ/status/ ... 4597608448
https://twitter.com/FredCookeNZ/status/ ... 8501246976
https://twitter.com/FredCookeNZ/status/ ... 0806331392
Sat Oct 07, 2017 5:47 am
Irony, get the car nice and clean, and the f***ing road markers come along and pointlessly repaint the stripes on either side of it and overspray onto the panels and wheels and tyres. Grrrrr. Just my luck. Especially ironic considering if it was still dirty, the paint would not have stuck, but because it's clean, it's stuck well! Arrrggghhh. Good thing it's not a minter in the first place.
https://twitter.com/FredCookeNZ/status/ ... 6382664704
Sat Oct 14, 2017 9:30 am
Took this for a welcome home drive last night, started straight up and settled into a silky idle just fine. The reluctance to start that it had when I bought it has gone away with some heavy use and quality oil.
Two new things:
1) Re the previous post, I bought some scrapers that don't hurt paint and do remove this hard but somewhat tall overspray: https://twitter.com/FredCookeNZ/status/ ... 6859738115
2) I bought a set of subframe locking bushes that I hope will cure some noises from the rear of the car for 60nzd + 8nzd shipping:
Mon Oct 30, 2017 4:02 am
The arrived the day before yesterday and look like this up close: https://twitter.com/FredCookeNZ/status/ ... 5758872576
Thu Nov 02, 2017 10:07 pm
A friend here at work recently pointed out that GTR diffs are R230 not R200. I didn't know R230 existed.
What I did know was that this car has the machined style diff input flange, just like GTRs do.
And then I found this photo which shows the R230 looking very similar with the machined flange:
I'll have to get under there and figure it out sometime soon. Would be cool if it was big stock. Makes sense with a 1580kg car, I guess.
Mon Nov 13, 2017 1:19 am
Installed the subframe locking bushes a few weeks back, still has a knock in the rear end, likely from the front diff bush play, I guess. Maybe trans mount or centre of driveshaft mount, though.
Changed the oil last night and discovered some gremlins: viewtopic.php?f=15&t=2693&p=44100#p44100
And lightened the car a bit by removing more parts of the plastic-cover-over-engine-for-no-reason system:
https://twitter.com/FredCookeNZ/status/ ... 5047939072
https://twitter.com/FredCookeNZ/status/ ... 7767860225
^ win. I hate that stuff...
So tomorrow night at the latest, I'll probably do the ATF flush, and maybe pull some covers off the cam belt to see if it's bad or can be tensioned out for the time being.
Need to use it in 1.5 weeks, so I'd better pull finger and get it "right" by then!
Wed Jan 10, 2018 1:33 am
Although, I haven't noticed the surging that was happening prior to that happening again, so perhaps those locking disks cured at least one thing. Will have to try to recreate on the motorway some time.
Wed Jan 10, 2018 1:35 am
RFB ATF MOFO changed: viewtopic.php?f=15&t=2693&p=44106#p44106
Thu Jan 11, 2018 10:23 am
Took the car apart and found that the cam belt was still in good shape. Will change it later in the year, but have the belt on hand:
https://twitter.com/FredCookeNZ/status/ ... 3179961344
https://twitter.com/FredCookeNZ/status/ ... 6615582726
And when I filled it up with 98 RON gas the other day, I thought it had a 65l tank, but I got 69 litres in:
https://twitter.com/FredCookeNZ/status/ ... 4480293888
But it turns out that it only has a 68 litre tank, after all:
https://twitter.com/FredCookeNZ/status/ ... 6794686464
Mon Jan 15, 2018 4:06 am
