I've gotten a bunch of items knocked off the to-do list:
✓ Fan rewired so it shuts off (if running) when the key is turned off
✓ Idle air valve tube added to valve and cold side IC tube, connected with hose. This should ensure the there's no boost leaking from the system via the idle valve
✓ New vband flange installed on downpipe second section- no more exhaust leak
✓ New ecu connection for map hose
✓ BOV - sticking/leaking fixed
✓ Aircon condensation leaking into footwell/out of floor pan- fixed
✓ cam cover gasket leaks everywhere because ancient - replaced
✓ fixed center console gauge light wiring (weak crimp)
✓ coolant fan gasket installed to protect radiator (replaced hack weather strip)
✓ Installed a new head unit with SD card and usb slot to replace the ancient CD player. Car is now 5lbs lighter.
