Pre weld prep: https://twitter.com/FredCookeNZ/status/ ... 2490689536
Tacked on: https://twitter.com/FredCookeNZ/status/ ... 4055508993
Welded back: https://twitter.com/FredCookeNZ/status/ ... 6249746433
Welded front: https://twitter.com/FredCookeNZ/status/ ... 3510515713
On three wheels 1: https://twitter.com/FredCookeNZ/status/ ... 0985916416
On three wheels 2: https://twitter.com/FredCookeNZ/status/ ... 8094340096
On three wheels 3: https://twitter.com/FredCookeNZ/status/ ... 4522727424
On three wheels 4: https://twitter.com/FredCookeNZ/status/ ... 0671699968
Purely optional plan for a slice of the weekend (not important to do any of it, but keen to do all of it):
- Crane up front, remove gas tank from underneath
- Remove heat shield from underneath
- Remove remaining brackets etc from inside (15 pieces all up, 2 done the other day, 17 total)
- Possibly drill out welds for tunnel reinforcement strips
- Remove entire dash temporarily
- Remove all things from behind dash, including loom
- Try to stop water ingress by sealing various things
- Reinstall dash in lightest possible stiff form
- Wire in trailer plug to tail lights and test
The next thing I'd be keen to do is a rough tunnel removal and a handbrake relocation to the back. With sufficient packing the king single could be used within it at that point :-)
