Impregacy's "Moar" 1991 Ingersoll 3012 (33rd)
If you're running FreeEMS on any engine whether it be in a vehicle or not, please post about it here!
Hayseed
Re: Impregacy's "Moar" 1991 Ingersoll 3012
Post by Hayseed »
On an air-cooled MS2 mower engine I screwed a small aluminum block to the head and drilled and tapped it for a Ford coolant temp sensor. It has worked fine.
Got a photo of that setup? I'm curious :-)
Hayseed
Post by Hayseed »
CHT Sensor: (the attachment bolt for the aluminum block is on the same axis as the sensor and hidden by the sensor once installed)
Overall engine:
24-1 crank wheel:
Hayseed
Post by Hayseed »
Cam Hall sensor: (running sequential injection, sensing intake valve retainer)
Fuel Pump:
Pump cannister filled by original engine mounted pulse pump:
Hayseed
Post by Hayseed »
Injector:
FPR:
Hmm, I guess reality is that you're typically at a fixed temperature pre-starting, and it would be accurate there. From there up, it would lag reality a bit more than a lower-inertia, closer-coupled setup, but you could account for that discrepancy by under-fueling compared to a different measure. And if you always started from cold, it'd track out fine anyway. The more lag that sensor has, the further it is from what the engine really needs, you can't really compensate for it everywhere, but it's likely not enough to care about, either. Cheers.
Hayseed
Post by Hayseed »
Sensor response speed has been a non-issue thus far in operation (~3 years). In this instance, "close enough" seems to have been close enough! ;)
Understood. But we're not here to aim for mediocrity; there is another project excelling in that arena. We're here to aim for the stars, and fall short with a full understanding of the problem.
Hayseed
Post by Hayseed »
Mediocrity = bad.
This "other project" of which you speak, sounds bad.
Go Fred, go! :D
