View unanswered posts | View active topics It is currently Sun Feb 28, 2021 8:23 pm
Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
Impregacy's "Moar" 1991 Ingersoll 3012 (33rd)
1991 Ingersoll 3012
12.5 HP Briggs and Straton Vanguard V Twin
90d V angle
Air cooled
42" Cutting deck
FreeEMS: Jaguar 0.6, Custom enclosure, Ignition only (for now), 2 GM LS style coils, ford truck VR sensor, GM 1 bar MAP, factory cooling fan is the 18-2 trigger wheel.
Current state:
Harness / Jaguar
EDIT: Previous discussions can be found here: viewtopic.php?f=67&t=2426
Thu Sep 25, 2014 1:19 am
Got the engine running now on the second jaguar--since I screwed up the first one. Same problem though of only firing on one cylinder. Could be something fundamentally wrong with my fixed config does this look right?
anglesOfTDC: {ANGLE(0), ANGLE(270)}, // v-twin 90 degree
outputEventPinNumbers: {0}, //
schedulingConfigurationBits: {0,0}, // Ignition only
decoderEngineOffset: ANGLE(125.00), //
numberOfConfiguredOutputEvents: 2, // Wasted spark
numberOfInjectionsPerEngineCycle: 1 // moot
It might be a little late to ask but a V-twin like this is supported right? or are the event too far apart lol!?
Fri Sep 26, 2014 2:27 am
No, that's definitely wrong! :-D You need to select your second pin on the second line. Both are being scheduled on pin 0 at the moment, which could be making for some interesting noises ;-)
Nice comment, re moot, very apt.
So if you have your coils on T2 and T3, for example, then you should have your outputEventPinNumbers as 0, 1, and so on up to T7 = 5.
Post a good video once you fix this and have it running mint :-D
Fred (at the ski town backpackers over 3g, after 5 hours drive on FreeEMS, hanging with an audi RS4 round some twisties, and having gotten out of bed at 5:30am, and now being 11pm, 100% dedicated to the cause)
Fri Sep 26, 2014 12:03 pm
thanks Fred, the mighty hotel can hang with RS4s or do you have your truck running?
BTW the MOAR was making wierd sounds. I had the wrong perception of what wasted spark would look like on a 2 cylinder. I also had the decoder offset backwards--I found in an older post that it is 360-whatIthought.
Here it is!
http://youtu.be/A2yLauXirZY
Bonus footage:
http://youtu.be/XQzJC4coeBU
Sat Sep 27, 2014 11:15 pm
The mighty hotel with me driving it can hang with most cars around corners :-) In a straight line, things are different :-D
That doesn't sound right. Your decoder offset with crank-mounted missing tooth wheel should be 0 to 359.98 inclusive, IE, less than 360.
Quote:
AWESOME! :-D Facebook, twitter and IRC have been notified! :-)
Sun Sep 28, 2014 4:21 am
Thank you Fred, for the neat program. Mad props to Fred, Andy, Michael, and everyone else who contributed. I really had a smile on my face as I mowed the lawn today--got some strange looks--especially from my brother in law when I tried to explain the wires dangling from the engine.
Regarding the offset, I had always thought of it as the angle past tooth 1 when at TDC but for FreeEMS it's more like the angle ramaining before TDC. Anyway I thought it would be 125 but instead is 360-125=235
I think I want to slap my wide band on next. Maybe fuel injection is in the works.
Sun Sep 28, 2014 4:50 am
You're most welcome, I bet I matched your smiles, and one-upped you with applause here in my bedroom watching your vid! :-)
Just read the "air cooled" part, what did you do for an engine temp sensor, point me at previous answer if I missed it :-)
You should put a camera on a tripod and film a piece of empty grass, then mow-into-scene, slowly mow across scene, then mow-out-of-scene again :-D Would make for an epic intro clip to a future presentation of some sort. No rush on delivery :-)
Sun Sep 28, 2014 5:19 am
nice, how about installing a turbo on it?
Sierra XR4i 2.0T
Sun Sep 28, 2014 11:52 am
Good question, it doesn't have one yet :/, I suppose that is next on the list also. Was planning to drill into the cylnder head somewhere, not sure where yet. I'm guessing the temps can vary greatly depending on where I put it.
Ha the thought has crossed my mind also. Anyone know of one small enough ~25 HP?
Mon Sep 29, 2014 2:45 am
Not an issue with only ignition control!
Before you fuel inject, yes.
Probably true, however the only thing that matters is that it's consistent and sufficiently different from "cold" to "hot". The closer it tracks chamber temperature, the better, too. More lag = less "accurate" enrichment. Search for what VW guys do to get some ideas. There is a good image someone posted on here for this. I can't recall who or where, though.
PM em_knaps and link to this thread for him to reply.
Mon Sep 29, 2014 6:03 am
