Impregacy's Jaguar 0.6 build
Impregacy
Re: Impregacy's Jaguar 0.6 build
Post by Impregacy »
Thanks Fred,
The V angle for the engine is 90d, does anyone's engine experience tell them what the TDC angle should be?
In other news. I worked some more on the proper enclosure. Made an end plate and notched the case to accept the TE connector that Andy spec'd out in his BOM. I'm too lazy to make an adapter board, but I noticed that the TE crimp plugs fit nicely over the connector pins, so I'm thinking to jumper to the board locations that way (like the wire I mocked up in the last picture). I'm a little concerened that they could shake off though.
Impregacy
Post by Impregacy »
Was able to do internal wiring tonight:
viewtopic.php?f=55&t=2523 < In use on #33 :-D
