View unanswered posts | View active topics It is currently Wed Jan 23, 2019 7:57 am
Reply to topic  [ 9 posts ]
FreeEMS Firmware Hacking Guide - Comments, Suggestions, etc
viewtopic.php?f=8&t=508
If you have something to add post it here. Ditto complaints, corrections, thankyous, comments etc.
Sun Nov 23, 2008 6:53 pm
1N4001 - Signed up
You bet you have a thank you coming. Thank you Fred, for all the work you're doing.
In rooting around, I found the NoICE Debugger. $99
http://www.noicedebugger.com/68hc12.html
It doesn't do the Xgate parts yet.
- Jim
Mon Nov 24, 2008 3:45 am
Hello,
Please can anyone answer the following questions :-
Is there an easy way to download all of the sourcefiles in one hit ?
Does the Makefile contain a list of all source files that it attempts to compile?
TIA,
Dave.
Fri Aug 08, 2014 9:32 am
You need Git! Get git, then clone the source, switch to the dev branch, the review the makefiles (quite a few, distinct purpose each). Git is required to be installed while building the firmware. If you change the system to not require git, you get zero support from me or anyone that wants to have my support in future. :-) Lots of info on git on the internet, good luck!
Fri Aug 08, 2014 11:36 am
Well Fred, I understood some of that :-)
I'll have a play around and then ask some more questions, if it doesn't p*** me off first.
Thanks,
Dave.
Fri Aug 08, 2014 11:59 am
Hello All,
I'm trying to clone a repository from Github and get this :-
fatal: repository 'https://github.com/fredcooke/freeems-vanilla/tree/master/src/main/' not found
What stupid thing am I doing ?
TIA,
Dave.
Fri Aug 08, 2014 3:16 pm
whizzo944 wrote:
Hello All,
Might be worth hopping onto IRC for more immediate responses, but if you just want the main repo, one way to create a local copy:
Code:
git clone https://github.com/fredcooke/freeems-vanilla
I've used git for various reasons (here and at work) and while it's pretty straightforward to those who use it regularly, it's always been a big hurdle for me. Keep us updated on your progress.
-Jeff
Fri Aug 08, 2014 3:45 pm
Put URL https://github.com/fredcooke/freeems-vanilla into git GUI and it worked.
Thank- You.
Dave.
Fri Aug 08, 2014 4:00 pm
From a dev perspective where are you with CAN etc. is there a current todo list we can nibble at while we do our thing?
Steve
Fri Sep 12, 2014 1:09 am
