"89 Nissan Patrol Y60
- masterkorp
- masterkorp
Re: "89 Nissan Patrol Y60
My super luxuous heating system, the nights are cold now.
Its starts to look like a car again.
- masterkorp
Okay i started soldering the jaguar 0.4 agains the OEM connector. I have 2 questions:
1) When I ordered the jaguar from Deuce, I didn't knew what rpm imputer combo to use, I asked him to to give me both Hall and VR resistor sets, because I have no idea what to use with Cam Angle Sensor, which ones should I use ? If I need to use anything else?
2) How should I wire up the ignition give I have 6 coils and the jaguar has 3 outputs ?
1 - For an Rb25 you will need a Hall setup. The OEM uses a logic IC and some protection/filter circuits made up out of passive components. I am not exactly sure what is available on the jag 0.4 you have to cater for this?
2 - Wasted spark FTW!
1 The RPM inputs on the 0.4 can be configured to be "good enough" for hall/nissan.
options:
2a from each ignition IC output, have two current limit resistors (you currently have just one) and run one from each channel to a different coil's ignitor channel
2b add another DIP8 IC to the board, run each IC output through a current limit resistor to an ignitor channel, and pair the inputs to the ICs at the CPU side to three pins
options:
- masterkorp
Guys before doing any real silly stuff. I do think that the hall components are correct. Sorry for the quality my camera really sucks taking up close pictures.
1) The resistor placement does look correct for Hall Effect inputs. The resistors should be 1k Ohm for the RPM0 and RPM1 inputs. You will also need to ground the RPM0- and RPM1- inputs for use with Hall Effect inputs.
2) For the ignition outputs you have Ignitor1, Ignitor2 and Ignitor3 outputs. The inputs to these circuits are IG1 (already connected via a trace to Port T2), IG2 (already connected via a trace to Port T3) and IG3 (which you will need to connect via a jumper wire to Port T4 (the square pad of P20 Port T4-7)).
