Jaguar 0.6-alpha progress
Re: Jaguar 0.6-alpha progress
I tested the PNP clamp circuit before, tomorrow I'll test the individual analog inputs and publish the results.
Ah yep I gotcha. Cool!DeuceEFI wrote:I tested the PNP clamp circuit before, tomorrow I'll test the individual analog inputs and publish the results.
mikehudsonuk
- TO220 - Visibile
another +1 - appreciate the updates and build photos for clueless wonders like myself
Acid testing the inputs:
With the 12v-SW input connected to a 13.2v battery positive terminal and the GND2 input connected to the negative terminal of the same battery the Analog-5v supply was measured at 5.00v.
I then applied 13.2v to each of the inputs and measured the Analog-5v rail with a DMM, here are the results:
TPS input: measured the Analog-5v rail at 5.15v, CPU-5v rail measured at 5.00v
O2 input: measured the Analog-5v rail at 5.15v, CPU-5v rail measured at 5.00v
MAP external input: measured the Analog-5v rail at 5.15v, CPU-5v rail measured at 5.00v
IAT input: measured the Analog-5v rail at 5.15v, CPU-5v rail measured at 5.00v
CHT input: measured the Analog-5v rail at 5.15v, CPU-5v rail measured at 5.00v
BRV input: measured the Analog-5v rail at 5.00v (as expected), CPU-5v rail measured at 5.00v
I then applied -13.2v to each of the inputs and measured the Analog-5v rail with a DMM, here are the results:
TPS input: measured the Analog-5v rail at 5.00v, CPU-5v rail measured at 5.00v
O2 input: measured the Analog-5v rail at 5.00v, CPU-5v rail measured at 5.00v
MAP external input: measured the Analog-5v rail at 5.00v, CPU-5v rail measured at 5.00v
IAT input: measured the Analog-5v rail at 5.00v, CPU-5v rail measured at 5.00v
CHT input: measured the Analog-5v rail at 5.00v, CPU-5v rail measured at 5.00v
BRV input: measured the Analog-5v rail at 5.00v, CPU-5v rail measured at 5.00v
I then connected all the inputs above to the +13.2v supply at the same time and verified that the Analog-5v rail and the CPU-5v rail stayed within tolerance (supply rail +/-0.3v according to Freescale specifications). The CPU-5v remained at 5.00v and the Analog-5v rail never was seen to go above 5.20v.
I then overloaded the TPS-5v output by connecting a 1 ohm 10W resistor between the TPS-5v output and ground and measured the voltage across the resistor (0.50v) which according to Ohm's Law equates to 0.50A (I=V/R). The Analog-5v rail remained at 5.00v and the CPU-5v rail remained at 5.00v. The TPS-5v output (at the solder pad, which is after the fuse, F1) was seen to go to 0.26v indicating the fuse opened the circuit.
More test results as they happen...
Good work, Andy! :-)
excellent results andy! our thorough design work on those protection and clamp circuits has paid off as expected!
It is a pleasure to read your progress posts
Here is a log from EMStudio of the S10 running on the Jaguar 0.6-alpha PCB. Just idling in the driveway with a slow rev up and back down a few times.
- 2013.10.18-10.56.42.bin.gz
- (1.26 MiB) Downloaded 1408 times
