Sean0 wrote:
The problem with just using a pure delta is that at low RPM only the fist X% of throttle movement will have an effect on airflow. IE if you are at idle and you wap the throttle to 50% there will be a huge increase in flow vs If you are lugging your engine on the highway and wap the throttle you may actually flood it out a bit. That was my reason for at least wanting to see how effective using the "fueling/PW delta" is.
Although this is true, the amount you need for initial opening is a small proportion of what you've already got at a wider opening.
Quote:
A carb pump doesn't know anything about RPM,
Fred wrote:
4) Carb pump works on volume, same volume is induced much faster at higher RPM. If you have a 200ms enrichment then that's tiny at low RPM and HUGE at high RPM. By volume automatically compensates.
Sean0 wrote:
It's sort of self-correcting. The accelerator pump dumps a flat amount of fuel based on throttle movement. The same movement at a higher RPM will automatically spread that shot out over more cylinder events.
I swear there's a fucking echo in here! If no LT1 log + vid + rip that all match in the next 7 days, I'm turning off your postability so you can focus better :-p
_________________DIYEFI.org - where Open Source means Open Source, and Free means Freedom
FreeEMS dev diary and
its comments thread and
my turbo truck!n00bs, do
NOT PM or email tech questions! Use the forum!
