This latest one doesn't have it. All is well. Carry on :-)flat4power wrote:can you made a mark on the picture to localise the point ?Fred wrote:What is the point of the top side ground traces on the caps/reg?
flat4power's Guepard - a VW type 1 oriented board
Re: Guepard board
- flat4power
Re: Guepard board
super
I continue tomorrow
thanks for your help
I continue tomorrow
Re: Guepard board
You should avoid ground loops too
Re: Guepard board
Please be more specific.johntramp wrote:You should avoid ground loops too
Re: Guepard board
looking good
Re: Guepard board
http://www.ultracad.com/articles/loop.pdfFred wrote:Please be more specific.johntramp wrote:You should avoid ground loops too
Re: Guepard board
Please don't be a dick on purpose.johntramp wrote:http://www.ultracad.com/articles/loop.pdfFred wrote:Please be more specific.johntramp wrote:You should avoid ground loops too
Re: Guepard board
How is pointing him to an article on the topic being 'a dick on purpose'? It can easily be improved with a copper pour on the top layer as well.
Re: Guepard board
OK, let me try to be more clear: Please point at something, anything, very specific, in his layout, that is wrong, and can be improved. The "copper pour" comment is along the right lines, but uses "as well" implying there is something else, which the article doesn't mention, because the author of the article has not seen this particular half-finished design ;-) I was wondering whether you simply failed to see what was missing or were being a smart arse. Clearly the former.
Re: Guepard board
By "as well", I was referring to "as well as the bottom layer". Going only by the small screenshot it looks like there hasn't been any consideration of return current paths. Eg. the ground path of the lower SMD IC inside the ignition block has a couple of paths out which all lead to pinch points.Fred wrote:OK, let me try to be more clear: Please point at something, anything, very specific, in his layout, that is wrong, and can be improved. The "copper pour" comment is along the right lines, but uses "as well" implying there is something else, which the article doesn't mention, because the author of the article has not seen this particular half-finished design I was wondering whether you simply failed to see what was missing or were being a smart arse. Clearly the former.
