View unanswered posts | View active topics It is currently Mon Jul 13, 2020 2:54 pm
Reply to topic  [ 67 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
Simple Cheap Compact IC-based High Performance Amp
KiCAD schematic has been updated as per the previous post.
https://github.com/DeuceEFI/Amplifier/c ... dc5d9e066d
Mon Feb 04, 2013 8:21 pm
Thanks! :-) Back to me for more progress, then :-/
Mon Feb 04, 2013 11:50 pm
Did some clearancing for the heatsink tonight. One more piece to cut/bend and i can look at fixing it down. Same goes for caps and bridges. It mostly sits where I want it now, so pretty soon I'll know how the boards need to look too.
Thu Feb 21, 2013 1:17 am
OK, heatsink is in place, though not bolted down, yet.
Boards should be wide, not long. up to 100mm wide, up to 50mm from heatsink to edge, smaller in either dimension == even better. But not at expense of crappy routing/placement.
A hole and empty bit in each heatsink corner for mounting brackets, please :-)
Like this, roughly:
Thu Feb 21, 2013 9:35 pm
Power in and speaker out should attach near heatsink somewhere and input signal at the back of the board away from heatsink. I think I talked about that in an earlier post? Feel free to seek clarification and/or to tell me to eff off :-)
Thu Feb 21, 2013 9:55 pm
Heatsink clearanced for tape deck mock parts, and mounted using three well aimed screws. The whole thing is stiffer as a result (ties back plastic to front steel).
Next up, power supply stuff, or maybe the TODO. I'll check that now and then edit this post.
viewtopic.php?f=37&t=1966&p=30972#p30972
Updated!
Sat Feb 23, 2013 5:39 pm
Power socket/switch/fuse holder installed. viewtopic.php?f=37&t=1966&p=30972#p30972
Will glue it in once it's wired up, and/or recess the clips so that they work. It's such a nice tight (hand cut!) fit, though, it barely needs it.
Pics later.
Mon Feb 25, 2013 10:20 pm
Only cap mounting and power distribution buses to go! viewtopic.php?f=37&t=1966&p=30972#p30972 Then it's down to the PCBs and IO wiring and fascia looks etc.
Time to get some progress made on the speakers now! :-)
Thu Feb 28, 2013 10:04 pm
Speakers are now semi usable, so I'm back to amp progress, but today, it's a different type ;-)
I've hijacked the amplifier module from those shitty Hama CS-482 PC speakers and am going to improve it a bit. Here's the baseline, or should I say bass-line, at 100 Hertz:
And at 50 Hertz:
Notice how the lower frequency signal has a much higher peak to peak? That's because it has a recovery time in between and gets recharged. You can watch the single-ended rail voltage sag during louder sections of music. Tomorrow I'll add 22000uF to the 2200uF that's in there, and retest with the scope. I bet it's louder, and possibly a bit clearer too.
Sat Mar 16, 2013 11:32 pm
Just quickly doing the math, looking at more than double the power output (4W vs 2W), under some circumstances. Should also give a more definite "too loud" point, rather than gradual muddying depending on signal material. Eg right now a transient following a bass note could be peaking at 2W but able to go to 4W if not preceded by a bass note. This will make it always be 4W, which is of course nothing compared to the ~50W it's going to be fed fairly soon :-)
Sat Mar 16, 2013 11:39 pm
