View unanswered posts | View active topics It is currently Wed Feb 20, 2019 11:01 pm
Reply to topic  [ 268 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27  Next
Daily WTF
Fred wrote:
Doh! Just realised, while talking to you, that I asked you to do something stupid.
LOL :-)
<3
Sat Dec 22, 2012 2:28 pm
Cylinder 5
Cylinder 4 may have a problem.
:-p
Sat Feb 09, 2013 11:33 pm
Weird! Cracked head? Loose spark plug?
Sun Feb 10, 2013 12:17 pm
When I first saw it I was thinking that it was a loose plug, but it was still tight. It's a 06 Chevy Colorado with a 3.5l I5. It's throwing a P0300 (multiple random misfire) code. It kinda looks like it has been getting way too hot. I was thinking maybe a bad cam bearing or a partiality seized piston. #4 still has 120psi compression. Which is pretty close to the same as the other cylinders. Except 3 which is at about 90. I don't know if it could get a crack 3 to 4 without leaking water.
:-p
Sun Feb 10, 2013 5:40 pm
edit a block of 5x5 with a single value in EMStudio hash 5194ba2b069d385e8cc1fc139f66d0bdb943d038
wc ~/Downloads/jesus_fucking_christ\!\!\!\!_too_much_code_running\!\!\!.txt
1011 6432 38718
http://pastebin.com/5Ai3QBM3
:-o
Time for some refactoring :-)
Sat Feb 16, 2013 3:53 pm
Code:
fred@raptor:/var/www/diyefi.org/forum$ git status | head -40
# On branch master
# Changed but not updated:
#   (use "git add/rm <file>..." to update what will be committed)
#   (use "git checkout -- <file>..." to discard changes in working directory)
#   deleted:    root/images/avatars/upload/75d761b1d587f1d90c18a2b051fd44b7_78.png
I love Git! <3
Code:
fred@raptor:/var/www/diyefi.org/forum$ sudo git checkout root/images/avatars/upload/75d761b1d587f1d90c18a2b051fd44b7_78.png
Sean! Busted deleting admin-installed avatar! :-)
Sat Feb 23, 2013 11:48 am
Joe Perez, 15 March 2013 "Modular high-level code is easy to create and a nightmare to debug."
Let me fix that: "Modular high-level code takes skill to create and is MUCH easier to maintain and debug."
Truly, WTF! :-/
Cross posted this to quote of the day too...
Fri Mar 15, 2013 8:27 am
These are both daily WTF and quotes, but here they are, you can guess the author(s):
"Serial problem - Receive txmode - driver or computer software problem"
Not from a forum, this in ASCII over RS232/USB/UART. WTF.
"This code (c)2007,2008,2009,2010 James Murray
Licensed for use on B&G approved hardware.
Hacking causes device damage.
Contact your reseller IMMEDIATELY."
"P responds to changes in error not error itself so just having a P term will keep you from reaching a target."
It'd be wrong to embarrass this person by naming them here.
Three words: WTF.
All of these are second hand, so if there are any errors, let me know.
Sun Aug 04, 2013 12:36 am
Three words: WTF.
Gee I could have sworn it is the "D is for Derivative" component that responds to change in error in a PID controller... :P
Keith MacDonald
Tue Aug 20, 2013 7:13 pm
gee why does the .XX code version not match what is displayed:
wire [15:0] fpga_sub_rev = 16'd80;
sprintf(version, "%x.%x%x", chVersion[2], chVersion[1], chVersion[0]);
You snooze, you lose!
Sat Nov 16, 2013 8:21 pm
Profile YIM
