View unanswered posts | View active topics It is currently Tue Nov 24, 2020 8:15 am
Sean's R1 Powered Desert Rail (17th)
Engine:
2003 Yamaha 998cc R1 (1st Bike engine).
16T Turbo
Two Injectors Per Cylinder
Hand Fabricated Sheet Metal Intake
ECU:
PowerEFI-F16 Running FreeEMS
FreeEMS additions:
XGATE Sequential + Staged Injection (1st)
MAF Fueling Algorithm (1st)
Image Image Image
Initial test run: http://www.youtube.com/watch?v=89UD5YJuqyY
You snooze, you lose!
Sun Jan 27, 2013 1:58 pm
Profile YIM
Congrats man! Needs more pics of the actual rail! :-p
Also, I thought an F16 was some sort of jet plane? :-p
Peow peow! :-)
Sun Jan 27, 2013 2:37 pm
This could be the first engine to be ran by FreeEMS that drinks JET-A ?
:-P
Sun Jan 27, 2013 2:38 pm
Congrats on the MAF Lazy Mobster. 8-)
Mon Jan 28, 2013 1:17 am
More pics of rail definately required!
Mon Jan 28, 2013 1:51 am
Naw the first FreeEMS engine to drink JET-A will prob be my truck :)
I suppose the name came from a few factors. I wanted a name that people could identify with(I'll admit it's a bit USAish). Fighter jets are know for being lean, mean, capable machines. I chose the F16 because I want to support 16 injector channels(fairly common requirement on overgrown *big-blocks, plus it put the "nay-sayers" dicks in the dirt).
Mon Jan 28, 2013 4:10 pm
Profile YIM
This makes me very happy.
BenFenner's 1994 Black SE-R
Fri Feb 01, 2013 11:13 pm
Some test and tuning. The engine tune seems to be pretty much dialed in, it didn't require any changes to the MAF table. Both injector sets are reading too high a duty-cycle for my liking, such is E85 I guess haha.
I clearly need to revalve the shocks, esp the rebound.
http://youtu.be/B9BN4i-rWnE
Sat Jul 06, 2013 12:25 am
Profile YIM
no changes to maf transfer function and being able to change to different injector sets says a lot imo.
Sat Jul 06, 2013 3:25 pm
The change was not the injectors, it was 7500 feet in elevation. I NEED to change one of the sets though. Maybe you can help me scout around? They are the skinny nippon-denso type. I currently have an orange set and a dark blue set. The *orange set is the primary and it's also the set it idles on. I'm showing .9 lambda at idle with a 2.1mS(3.1 effective), so there seems to be room to go to a bigger injector without creating a messy situation. Or maybe leave that set and just get a BIG set for the secondaries, that's prob the better thing to do......
Sat Jul 06, 2013 5:19 pm
Profile YIM
