Simple Cheap Compact IC-based High Performance Amp
Non-EMS Electronics related discussions and projects in here please.
Re: Simple Cheap Compact IC-based High Performance Amp
TODO updated, next up is cap and ground lift mounting. Then find fuse holders that are suitable. Lastly, I'll wire up the power supply and test that.
After that I wait for the heatsink to arrive, schematics to be drawn up, or do them myself, PCB layout to be done, or do it myself, then order, assemble, and enjoy!
NO! I _STILL_ haven't found any reasonable secondhand speakers to buy :-( This might be the biggest challenge of all.
Today, what better to do than assemble some heavy-duty circuits! Pics to come in next post, but for now: TODO updated!
Current TODO consists of:
  • Install new power socket/switch/fuse
  • Bolt down both bridge rectifiers
  • Figure out how to mount the filter caps and do it
  • Wire up all power supply components and test
And then finally:
  • Get schem/layout done
In order:
1) Snubber caps on main bridge
2-6) Ground lift circuit
Heat sink arrived! It has a somewhat "Don't fuck with me!" look to it, so I thought I'd play the same part for the shot:
Usually I'm smiling in photos, so today I thought I'd be different. This is as close as I can fake to "Furious Fred" like the one that appears when people nearly run him over in Barcelona.
SleepyKeys
Post by SleepyKeys »
Wait a minute, that pic looks familiar........
You snooze, you lose!
ROFL! Copyright infringement!!! :-o So I stole it back. Cached here as you've lost files from your server in the past ;-)
SleepyKeys
Infringe this!!!!!
I sure hope that this amp doesn't make any smoke! :-(
SleepyKeys
With that heat sink, I think you are covered. I would be more worried about gun smoke from your neighbors, after you turn the volume up :)
ROFL!
