Max Square Wave Latency
Re: Max Square Wave Latency
Yes! :-)
1) Verify latency with 10k/10k/1nF input setup and 5V square wave signal on VR+ with VR- floating
2) Verify reduced latency with capacitor removed and same setup
3) Fix VR- @ 2.5V and measure latency
4) Still fixed @ 2.5V, reinstall cap and measure latency
5) Still fixed @ 2.5V with cap, reduce resistance from 10k to 1k and measure latency
I can't think of more things to try with it than that, but if you can, feel free to play around more! :-)
Dan
Post by Dan »
No probs! Will do ASAP!
Just ordered a Saleae Logic16! (3-5 days delivery)
Will keep you posted! :-)
Those are cool, and quite big! :-) I look forward to seeing pretty photos of your bench + it.
Dan
Post by Dan »
sweet! glad I made a "good" choice then. The Open one you told me about just looked a little tacky. . . . LOL
Yes, we've all seen your valve cover ;-)
What we haven't all seen is the car that your Mrs has! :-o
Another thing to try is watch the floating negative pin with the second channel of a scope and see what it's doing. I have a hunch that even without the cap it is moving around a lot. Hence the suggestion of fixing it at 2.5V and watching the latency then.
Dan
Post by Dan »
my Logic16 just arrived :-)
testing to follow soon!
While you're at it, how about testing 1k instead of 10k for the input resistors, with std cap and floating -ve, i bet it's still bad. Prove me wrong :-)
Dan
Post by Dan »
My Test Results in the form of traces from my Logic16 are as follows, in order of tests requested.
and a new item,
6) With cap and two 10k resistors, feed square wave into VR+ and same inverted square wave into VR-
Dan
Post by Dan »
Just to be picky, I will also throw up some LA traces with actual latency measurements.
2) Verify reduced latency with capacitor removed and same setup - with actual lag time
3) Fix VR- @ 2.5V and measure latency - with actual lag time
4) Still fixed @ 2.5V, reinstall cap and measure latency - with actual lag time
5) Still fixed @ 2.5V with cap, reduce resistance from 10k to 1k and measure latency - with actual lag time
6) With cap and two 10k resistors, feed square wave into VR+ and same inverted square wave into VR- - with actual lag time
