Jaguar 0.4-alpha PCB Status (was Jaguar A4 PCB Status)
DeuceEFI
Re: Jaguar A4 PCB Status
Post by DeuceEFI »
Updated Jaguar/dev branch with X-OR part number for devices rated for 24mA, changed Crank and Cam input names to RPM0 and RPM1, added PK4 and PK5 solder pads to allow those outputs to be used and finally added a picture of the GM 4 cylinder DIS/Injection Timing.
Here's a link to the latest changes: http://git.io/SUyFSA
Re K4/K5, you may want to bring out more interesting pins and change the config to suit. GP outputs don't HAVE to go there :-)
Dan
Post by Dan »
DeuceEFI wrote:
I have EMStudio communicating to the MCU through the ADUM1201 wonderfully, I have had it running for the last 48 hours without any issues :-)
Next up is to test the Texas Instruments/Dallas Semiconductor ISO7421ED which is supposed to be a drop in pin for pin replacement for the Analog Devices ADUMx201 series.
Any updates with this mate?
+1, super keen for this info! :-)
flat4power
Post by flat4power »
just for having news ;)
DeuceEFI
Post by DeuceEFI »
I have installed the Texas Instruments/Dallas Semiconductor ISO7421ED digital isolator on malcom2073's Jaguar A3 board and have verified that it works with similar results to the ADUM1201WTRZ digitial isolator. I will post a Saleae trace of the I/O this evening before packing the board for shipment.
With that being said, I will remove the ADUM1201 from my Jaguar A2 development board and replace it with an ADUM3201 for testing.
Thanks Andy!!! :-)
DeuceEFI
Post by DeuceEFI »
I have tested the Texas Instruments/Dallas Semiconductor ISO7421ED digital isolator and have included the Saleae Logic trace of both RX and TX from both the MCU and from the FTDI chip.
From the trace you will see there are no timing issues between the inputs and the outputs.
This chip is a pin for pin compatible with the Analog Devices ADUMx201 series of digital isolators.
p.s. you can down load the Saleae Logic program from http://www.saleae.com/downloads
ISO7421ED-Test.logicdata.zip
Texas Instruments/Dallas Semiconductor ISO7421ED Digital Isolator Saleae trace of serial communications.
(463.44 KiB) Downloaded 871 times
DeuceEFI
Post by DeuceEFI »
Same test, sampled at 24MHz
ISO7421ED-Test-24MHz.logicdata.zip
(114.08 KiB) Downloaded 858 times
Mint!
