Wiring during construction, clearly seen the different locations of signal wires, driving wires and starting/charging wires.
Left = Relay box
A = Acc relay
E = ECU relay
F = Fuel pump relay
30 A fuse from battery
Center = Starter Relay
Right = Ignition driver
Wiring of the relays, all feed via the blue wire.
Clearly I didn't take this photo... My wonderful helper and camera operator Rula did!!
Under the control panel still along way to go there.
