Hentai's Project Ditch-MS2
Hentai
Re: Hentai's Project Ditch-MS2
Post by Hentai »
So awesome! <3
Hentai
Post by Hentai »
http://youtu.be/oVd2rOwRlkE
working cas input using 4+2 cas disc
Dan
Post by Dan »
This is awesome! Die megasquirt Die!!!!
Keep up the good work! :-)
Hentai
Post by Hentai »
unfrountaly I slowed down recently.
But I'm back and plan to get my harness crafted and done up ready. Then I will hook it up and test sensor inputs are working properly.
DeuceEFI
Post by DeuceEFI »
Cool, welcome to the land of always busy with other projects...
Thanks for the update :-)
Hentai
Post by Hentai »
I'm so excited I just can't hide it!
so success and failure.
Still no running on jaguar yet, but we have gotten couple pops and bangs and puffs out the engine.
Spark is getting to the plugs but its not good enough to light up the timing light.
Hentai
Post by Hentai »
I also changed the resistors to 100 ohm resistors
Hentai
Post by Hentai »
Here is a datalog using the miata\dsm 4+2 cas and ls coil packs
I believe I am getting sync loss right now.
Includes couple starting cranks in it.
1815 16 nov 2012.7z
(175.47 KiB) Downloaded 668 times
