Everything is rubbery to you :-p
I'll start with the MD file. The reason I didnt start there is because the time spend on the MD file could be spent on getting cross-builds working. I'm sure 99% of windows users are more concerned with a bin than knowing how to build from source.
-sean
FreeEMS_Loader
- SleepyKeys
Re: FreeEMS_Loader
You snooze, you lose!
Re: FreeEMS_Loader
Rubbery = Lovely pronounced funny. :-p
Agreed re bins vs source, but incomplete/never-finished docs are incomplete/never-finished docs.
Re: FreeEMS_Loader
(I was saying the
guy looks like he's twiddling his fingers like I was)
Anywho, hurrah, progress!
I'll give that a jam.
Just wanted to know how it was going is all
Will report back.
Will report back.
Re: FreeEMS_Loader
Craig: viewtopic.php?f=41&t=560&p=28325#p28325
Try that sucker, it's old, and made by dave, but may work. Worked for Andy on win 7.
Re: FreeEMS_Loader
Ok the s19 version can up and run.
Excellent Sean, thanks
(though I can only report of it running atm)
I think I muffed the usb mod on my board and ended up with a hard short after resoldering things... hmm.
Couldn't summon anything when looking at the usb hub when powering/connecting it.
So I'm talking with Aaron who has a magical enchantment or some such which will use it's strong kung fu to bypass the spawn of evil that is the usb on the puma board.
You've probably already moved on as I see a Loader thread has many posts.
TBA.
TBA.
Re: FreeEMS_Loader
Sean,
Help I cant build the loader.... http://issues.freeems.org/view.php?id=710 I created a tracker report.
I'm quite sure I followed the instruction correctly, maybe, maybe not.
If I get this working then I'm only using freeEMS products.... thats pretty sweet!
Helpppp please. I'll share my chuddy with you
Preston.
Preston.
- SleepyKeys
Re: FreeEMS_Loader
Yep, Fred replied with what I was about to say. I need to update the docs etc. You will have to build the serialIOLib before you can sucessfully compile the loader though. Let me look at the docs and see what I can fill in. Do try qmake && make from the src/ dir .
thx!
thx!
Re: FreeEMS_Loader
Cheers, I tried to build from src, the qmake looks like it works but not the make.
Preston.
Preston.
Re: FreeEMS_Loader
Fixed.Sean0 wrote:Do try "qmake && make" from the src/ dir .
Presto is likely following more of your instructions :-p
plain make presto.
- SleepyKeys
Re: FreeEMS_Loader
Presto, please see the issue tracker for my latest post about this issue. thx!
