View unanswered posts | View active topics It is currently Wed Jan 20, 2021 7:39 am
Reply to topic  [ 81 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
Reflow Fred Style! :-)
A few pics to illustrate just exactly how hot it got in there...
So I decided to make the baking tray for the PCBs out of the alloy (this is where Abe got all upset).
But it didn't fit properly, because I'd put too much glass fibre insulation in between the layers.
And the heat made it bow from expansion anyway, so I "fixed it" (pun intended) with a couple of screws.
And called it good. Tune in next time for the high-tech electronic side of the modifications! :-)
To be continued...
Sun May 20, 2012 7:10 pm
As you may recall, I baked the thermocouple IC first, by feel.
First I dismantled the thermocouple and recorded the polarity of the cable going
into the plug by orientation of the printing on the shrink sleeve.
Then I loaded up the schematic and started getting artistic with components! :-p
Things seemed to be going well, so it was time for the first cold-on-hot-off-cold test! :-)
The circular thing on the little circular PCB is a piece of solder so I could tell when it was hot enough.
I didn't actually get a reading from the thermocouple this time around, so I killed it before it got hot.
To be continued...
Sun May 20, 2012 7:30 pm
After some scratching of my head, and chatting to DeuceEFI on IRC, I realised that I had
simply been ignorant and ignored a crucial but unimportant-looking part of the schematic.
In the process my thermocouple wire got shortened a significant amount :-)
But, it was time for another test!
This was the noisy test that I posted earlier, but largely a success.
The thermocouple wire insulation showed signs of being plenty hot.
And the noise meant that I thought I'd follow the schematic even more closely and add some filtering.
Plus, the expansion forced the door partly open from about 200C up, so I fixed that too.
It must be time to control it! :-)
I don't have the rest of the pics handy right now, but I'll try to find them and do another post soon.
To be continued.... but not today! :-)
Sun May 20, 2012 7:42 pm
viewtopic.php?f=9&t=1621 < johntramp, now it is! :-p
Thu May 24, 2012 12:18 am
How many people bugged me about these pics? How many of those commented at all? Poor form.
Today the oven baked another tcouple IC. Tonight I have two working and tested. Tomorrow I might do some experiments!
Sat Jun 02, 2012 12:38 am
I was skeptical about the need to insulate and double plate the unit, but you sure as hell have it down to a predictable state, which is nothing short of impressive.
You need to come up with a logo, such as:
Oops...wrong image. Maybe more like this:
bread.jpg [6.19 KiB]
Not downloaded yet
Sat Jun 02, 2012 4:31 am
Classic. Do you think the insulation helped much? And have you tried your slice of bread heat distribution test again with the alloy plate?
Sun Jun 10, 2012 2:02 am
Yes, a LOT. You can almost touch the top and back with the inside @ 300C now. Before you couldn't get closer than about 10cm from the back - the radiated heat was too much.
No, but that's a stellar idea! If we obtain another bimbo for thorough use, I will commandeer some for this purpose.
Sun Jun 10, 2012 6:16 am
Hey Fred. I thought that you might like this. :lol:
http://hackaday.com/2012/06/18/toaster-over-reflow-project-goes-way-overboard/
Wed Jun 20, 2012 2:05 am
LOL :-p
The actual link, for those wishing to short cut Aaron's trickiness ;-)
http://hobbybotics.wordpress.com/projec ... ler-v8-03/
Wed Jun 20, 2012 8:59 am
