I have drilled out the PCB for the through hole components and run the PCB through a reflow soldering cycle in my Wally World special toaster oven to install the Freescale 112pin MCU, the FT232RL USB-Serial converter and the opto-isolators.
Attached are some photos I snapped during the reflow cycle and of both sides of the PCB during testing.
Notice that the optos are missing in the SMT photo, I was having a problem with it communicating between the FT232RL and the MCU so I removed the optos and the associated resistors to make sure it would work without them in the circuit.
At this point it communicates flawlessly with MTX and I am able to flash firmware with both Sean's freeems-loader and the MTX loader, so now I just need to figure out the problem I had with the optos (data was getting corrupted between the FT232RL and the MCU).
More to come, stay tuned...
