Jaguar Repository on GitHub.com
DeuceEFI
Post by DeuceEFI »
Where to find the files for the Jaguar Project
https://github.com/DeuceEFI/Jaguar
DeuceEFI
Re: Jaguar Repository on GitHub.com
Post by DeuceEFI »
Latest changes committed/pushed to github:
Notes for GM DIS versus Ford EDIS setups
Added the ability for:
4 cylinder Sequential Injection
8 cylinder Semi-Sequential Injection
adding to the already planned:
6 cylinder Semi-Sequential Injection
6 cylinder Sequential Injection (when firmware supports it).
Updated BOM and PDF Schematics.
DeuceEFI
Post by DeuceEFI »
Added additional FET to control Radiator cooling Fan off of Port A5, Updated BOM (it is now current and correct for this revision), updated the PCB layout and updated the Jaguar-Schematic.pdf file.
All these changes have been committed/pushed to github for review.
gixxer-harry
Post by gixxer-harry »
Thank you very much for all your hard work
And again i want to thank all for the work your doing
If there is any thing i can do for you than please do ask
DeuceEFI
Post by DeuceEFI »
No worries :-)
Be sure to check back for updates to my github repository as I have been making multiple changes per day for the last week as I have been working with others to make sure the circuits are correct.
I still need to decide on a connector and map the inputs/outputs to the pins of the connector.
Next comes the documentation on how to assemble the PCB.
Still quite a bit to do, but we will get to the end where we can run engines (that is more than one :-)
DeuceEFI
Post by DeuceEFI »
Added Connector Board schematic and PDF for Jaguar PCB to my repository under the "connector" directory.
DeuceEFI
Post by DeuceEFI »
Added an xoscope view of TACH output from DIS module (green trace on channel 1) and the EST Advance input to the DIS module (blue trace on channel 2) to my repository.
EDIT: The file is called Ignition-Timing.png and it is in the "docs" directory.
Is that with OEM or MSPOO running it? :-) And I assume that more recent data is on the right? It's been a long time since I ran that app!
DeuceEFI
Post by DeuceEFI »
Fred wrote:Is that with OEM or MSPOO running it? :-) And I assume that more recent data is on the right? It's been a long time since I ran that app!
That is with the MSPOO running it, from this morning.
Time = 0 on the left and increasing as you go towards the right.
No chance of seeing what the OEM do, is there? I don't trust them to have done it right :-)
