Hello Fred,
You must know that the map is for an MS, I haven't even begun to fully understand FreeEMS yet.
If I can make a suggestion to you, could you possibly do a "FreeEMS State of the Nation" address to your followers,
so that everyone knows where the latest hardware and firmware developments are, of course not wanting to divert
your attention from firmware development, which seems to be your main focus at the moment, if I'm reading between
the lines correctly.
The bike has a MS2 on it, ultimately I would like to try FreeEMS on it. The MS2 thinks that it's running a V8,
the engine has a 360 deg crank, i.e. both rear and both front pistons are up together, so I am just using spark outputs
1 & 2 and just ignoring the other 2. The ultimate aim is sequential injection, I can run the engine sequential spark or
wasted spark, it doesn't make much difference. When you mention a "Flat Map", do you mean just a slope in the load
axis , or totally flat, which wouldn't make much sense to me? The load sensor is the TPS, not the MAP sensor, so I assume
that the slope won't be linear.
Sometimes I am very hesitant to ask questions here, I feel like I'm taking without giving anything back. Do you have a beer fund
that I can contribute to, that is if you ever find the time to drink beer !!
The reason for not telling you what I'm doing is because I thought my project vehicle doesn't have enough wheels to be interesting
to people here
A Thousand Thanks for your help,
Dave.
