They need to test the JAW. It is completely digital like the Innovate and so I have hope for it.Admin wrote:Here is that article from the magazine showing that only AEM and Innovate are accurate enough :
http://www.emspowered.com/vb/showthread ... t=wideband
Admin.
Nifty Wideband to Check Out [JAW, old thread]
Re: Nifty Wideband to Check Out
Keith MacDonald
Yeah, that would be nice. Although, given that LC-1 IS accurate, a simple side by side would be sufficient to get a good idea of how good/bad the JAW is. I also hold out high hopes for it :-)
Good point, I'll see if I can get someone to run both on the same car.
It does turn out to cost a bit, after you get all the parts.... $150 is not an unrealistic JAW budget to actually get running. Then again, you get a gauge for that much. Something I'm *sorely* lacking in my current, innovative set up. Two programmable outs and a digital display is pretty attractive.
Perhaps I can trick the MS to logging them both.
-Abe.
interestingly, the speed was something they listed, but so was having a real time guage (cheaper on the jaw) and free air calibration (also something the jaw does). Not saying it's better, or even as good, but that it has potential.
I will say, seeing it in person, that it's a bit big, and the readout board is laid out poorly, being twice as large as it needs to be. I'm a fan of compact, not all of us drive trucks.
-Abe.
A digital gauge is very easy to implement for any 1-2v output. I swear it used to be in the Innovate manual, but I can't see it anymore...
It both wastes an output, and isn't terribly accurate.
I'm a bit curious, btw, about just how accurate any analog communication can be. These gauges scare me.
It seems repeatability is more important than an actual absolute number, everything I see tuned has AFR's "between 12 and 13", you know? Not like they hit 12.485:1 and hold it all the way across, certainly not after a competent tune.
Oh contrare, it's perfectly accurate, and, what on earth would you want to use the other output for?? 1 x ECU, 1 x Gauge = FTW (pretty sure that's why they stuck them there)8InchesFlacid wrote:It both wastes an output, and isn't terribly accurate.
With proper grounding techniques it will be very good. You literally output a voltage between 1 and 2 with the lc1 which corresponds to 10 - 20 afr and then measure that voltage with (duh) a voltmeter and use the jumpers on it to shift the decimal down one place. This is what I'll probably be doing unless I get lazy and buy a moates ometer.I'm a bit curious, btw, about just how accurate any analog communication can be. These gauges scare me.
It's not terrible. Sure, you're losing some accuracy (there's two bits just in using only 1V of range out of a 5 V possible), but there's no arguing with the accuracy of a digital signal. I wish the computer could get one.
Hmmm, perhaps it can, I wonder how the display on that works.
Much as I hate parallel installs, you can have uses for two outputs and a guage.
1) Like in my car, I have TWO guages, and the computer
2) People running in parallel often want to feed the OEM ECU a signal so the stock computer can run off it. Also good if they are using soley the OEM ecu, without an aftermarket EMS.
3) Someone who wants to datalog with a stand alone logger.
8InchesFlacid wrote:1) Like in my car, I have TWO guages, and the computer
Otherwise, yes, you are right about the 1/5 thing, and OK, oem + standalone + gauge, but who the hell would do that...
I agree digital would be nice. I'd like to see that as an option on ours too.
Does anyone know the serial interface spec for the LC-1 ?
lc1lc1lc1... Why not get the serial spec for the JAW?
With precious little redesign, that whole thing would fit easily within any ecu box. I should ask the guy how much power it takes, turning it into a MS-card would be awesome. And a digital interface for the FreeEMS would be good, too.
-Abe.
-Abe.
Because I own and LC1 and I don't own a JAW (yet). Both would be good for sure :-)
