Please post input in this thread
http://www.diyefi.org/forum/viewtopic.php?f=10&t=560
FreeEMS-Loader Development Log (do not reply)
- SleepyKeys
You snooze, you lose!
- SleepyKeys
Re: FreeEMS-Loader Development Log (do not reply)
I added a few visual todo's based on Fred's input(thanks), and have yet to finish the requested features todo list. The idea of an action queue sheet in stead of buttons for all actions has been proposed, we'll see what the judges say.
-sean
-sean
I know you said not to reply, but... I'm in charge :-) I jest I jest. I know you're not working on this right now, but can you bang it up on github soon just in case someone else wants to play with it? Headers, license file, readme and a little bit of dir structure etc would be sweet :-)
Hey Seank,
Followed install instructions exactly and the compiler output is as follows.
I installed the boost and winGW files and rebooted Windows (you just cant trust windows not to do something odd)
Hope this helps
Running build steps for project FreeEMS_Loader...
Configuration unchanged, skipping qmake step.
Starting: "C:/Qt/2010.05/mingw/bin/mingw32-make.exe" -w
mingw32-make: Entering directory `C:/Documents and Settings/el_presto/ECUmanager/freeems-loader/FreeEMS_Loader-build-desktop'
C:/Qt/2010.05/mingw/bin/mingw32-make -f Makefile.Debug
mingw32-make[1]: Entering directory `C:/Documents and Settings/el_presto/ECUmanager/freeems-loader/FreeEMS_Loader-build-desktop'
g++ -c -Wall -Werror -g -Wall -frtti -fexceptions -mthreads -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_XMLPATTERNS_LIB -DQT_XML_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\2010.05\qt\include\QtCore" -I"c:\Qt\2010.05\qt\include\QtNetwork" -I"c:\Qt\2010.05\qt\include\QtGui" -I"c:\Qt\2010.05\qt\include\QtOpenGL" -I"c:\Qt\2010.05\qt\include\QtXml" -I"c:\Qt\2010.05\qt\include\QtXmlPatterns" -I"c:\Qt\2010.05\qt\include" -I"c:\boost\include\boost-1_45" -I"c:\Qt\2010.05\qt\include\ActiveQt" -I"debug" -I"." -I"..\src" -I"." -I"c:\Qt\2010.05\qt\mkspecs\win32-g++" -o debug\FreeEMS_LoaderThreads.o ..\src\FreeEMS_LoaderThreads.cpp
Makefile.Debug:133: warning: overriding commands for target `debug/moc_FreeEMS_LoaderComms.cpp'
Makefile.Debug:123: warning: ignoring old commands for target `debug/moc_FreeEMS_LoaderComms.cpp'
Makefile.Debug:140: warning: overriding commands for target `debug/moc_freeems_loader.cpp'
Makefile.Debug:130: warning: ignoring old commands for target `debug/moc_freeems_loader.cpp'
Makefile.Debug:147: warning: overriding commands for target `debug/moc_freeems_loader.cpp'
Makefile.Debug:140: warning: ignoring old commands for target `debug/moc_freeems_loader.cpp'
Makefile.Debug:154: warning: overriding commands for target `debug/moc_freeems_loader.cpp'
Makefile.Debug:147: warning: ignoring old commands for target `debug/moc_freeems_loader.cpp'
Makefile.Debug:175: warning: overriding commands for target `ui_freeems_loader.h'
Makefile.Debug:172: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile.Debug:178: warning: overriding commands for target `ui_freeems_loader.h'
Makefile.Debug:175: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile.Debug:181: warning: overriding commands for target `ui_freeems_loader.h'
Makefile.Debug:178: warning: ignoring old commands for target `ui_freeems_loader.h'
In file included from c:\boost\include\boost-1_45/boost/asio/basic_datagram_socket.hpp:18,
from c:\boost\include\boost-1_45/boost/asio.hpp:20,
from ..\src\/FreeEMS_LoaderComms.h:14,
from ..\src\/FreeEMS_LoaderThreads.h:13,
from ..\src\FreeEMS_LoaderThreads.cpp:8:
c:\boost\include\boost-1_45/boost/asio/detail/config.hpp:59:5: error: #warning Please define _WIN32_WINNT or _WIN32_WINDOWS appropriately.
c:\boost\include\boost-1_45/boost/asio/detail/config.hpp:60:5: error: #warning For example, add -D_WIN32_WINNT=0x0501 to the compiler command line.
c:\boost\include\boost-1_45/boost/asio/detail/config.hpp:61:5: error: #warning Assuming _WIN32_WINNT=0x0501 (i.e. Windows XP target).
cc1plus.exe: warnings being treated as errors
In file included from c:\boost\include\boost-1_45/boost/asio/ip/address_v6.hpp:227,
from c:\boost\include\boost-1_45/boost/asio/ip/address.hpp:22,
from c:\boost\include\boost-1_45/boost/asio.hpp:46,
c:\boost\include\boost-1_45/boost/asio/ip/impl/address_v6.ipp: In constructor 'boost::asio::ip::address_v6::address_v6()':
c:\boost\include\boost-1_45/boost/asio/ip/impl/address_v6.ipp:37: error: missing braces around initializer for 'in6_addr::<anonymous union>'
c:\boost\include\boost-1_45/boost/asio/ip/impl/address_v6.ipp:37: error: missing braces around initializer for 'u_char [16]'
c:\boost\include\boost-1_45/boost/asio/ip/impl/address_v6.ipp: In static member function 'static boost::asio::ip::address_v6 boost::asio::ip::address_v6::loopback()':
c:\boost\include\boost-1_45/boost/asio/ip/impl/address_v6.ipp:259: error: missing braces around initializer for 'in6_addr::<anonymous union>'
c:\boost\include\boost-1_45/boost/asio/ip/impl/address_v6.ipp:259: error: missing braces around initializer for 'u_char [16]'
In file included from c:\boost\include\boost-1_45/boost/asio/ip/detail/endpoint.hpp:139,
from c:\boost\include\boost-1_45/boost/asio/ip/basic_endpoint.hpp:20,
from c:\boost\include\boost-1_45/boost/asio.hpp:49,
c:\boost\include\boost-1_45/boost/asio/ip/detail/impl/endpoint.ipp: In constructor 'boost::asio::ip::detail::endpoint::endpoint(int, short unsigned int)':
c:\boost\include\boost-1_45/boost/asio/ip/detail/impl/endpoint.ipp:60: error: missing braces around initializer for 'in6_addr::<anonymous union>'
c:\boost\include\boost-1_45/boost/asio/ip/detail/impl/endpoint.ipp:60: error: missing braces around initializer for 'u_char [16]'
mingw32-make[1]: Leaving directory `C:/Documents and Settings/el_presto/ECUmanager/freeems-loader/FreeEMS_Loader-build-desktop'
mingw32-make: Leaving directory `C:/Documents and Settings/el_presto/ECUmanager/freeems-loader/FreeEMS_Loader-build-desktop'
c:\boost\include\boost-1_45/boost/system/error_code.hpp: At global scope:
c:\boost\include\boost-1_45/boost/system/error_code.hpp:214: error: 'boost::system::posix_category' defined but not used
c:\boost\include\boost-1_45/boost/system/error_code.hpp:215: error: 'boost::system::errno_ecat' defined but not used
c:\boost\include\boost-1_45/boost/system/error_code.hpp:216: error: 'boost::system::native_ecat' defined but not used
c:\boost\include\boost-1_45/boost/asio/error.hpp:251: error: 'boost::asio::error::system_category' defined but not used
c:\boost\include\boost-1_45/boost/asio/error.hpp:253: error: 'boost::asio::error::netdb_category' defined but not used
c:\boost\include\boost-1_45/boost/asio/error.hpp:255: error: 'boost::asio::error::addrinfo_category' defined but not used
c:\boost\include\boost-1_45/boost/asio/error.hpp:257: error: 'boost::asio::error::misc_category' defined but not used
c:\boost\include\boost-1_45/boost/asio/error.hpp:259: error: 'boost::asio::error::ssl_category' defined but not used
c:\boost\include\boost-1_45/boost/asio/detail/winsock_init.hpp:78: error: 'boost::asio::detail::winsock_init_instance' defined but not used
mingw32-make[1]: *** [debug/FreeEMS_LoaderThreads.o] Error 1
mingw32-make: *** [debug] Error 2
The process "C:/Qt/2010.05/mingw/bin/mingw32-make.exe" exited with code %2.
Error while building project FreeEMS_Loader (target: Desktop)
When executing build step 'Make'I installed the boost and winGW files and rebooted Windows (you just cant trust windows not to do something odd)
Hope this helps
CLI output redirected
Error:
Error while reading: Undefined error: 0
ðá¿_ÿ
set flash type to
S12XDP512
set flash type to
S12XDP512
set flash type to
S12XDP512
Error:
ðá¿_ÿ
set flash type to
S12XDP512
set flash type to
S12XDP512
Error:
ðá¿_ÿ
set flash type to
S12XDP512
Error:
ðá¿_ÿ
set flash type to
S12XDP512
set flash type to
S12XDP512
Error:
ðá¿_ÿ
set flash type to
S12XDP512DIYEFI.org - where Open Source means Open Source, and Free means Freedom
