Turbo'd Slaters TA build.
em_knaps
Post by em_knaps »
Greeting's fellow petrogeeks,
Under orders from fearless Fred I created this thread for the TA/vero build i intend to run my turbo'd EFI'd Citroen GS with
EDIT: Comments here: viewtopic.php?f=62&t=1337
these are images of the car (above), and the beginnings of the TA/vero ECU (below)
Indeed Fred commented that it was a long motherf****r, I could not help but blush.
the Engine is a 1299cc engine from a later model Citroen GSA with a toyota trans speed sensor replacing the original diagnostic TDC sensor and the flywheel machined with 10 more grooves in it to create a 12-1 type signal.
injectors are 300cc from a some sort of Ford mounted in the original manifold runners.
Igniton is achieved with a subrau wasted spark coil and igniter.
Up till now the car has run reliably 1st on a MS1 V3 board then downgraded to a MS1 V2.2 when I stole the V3 for my supra.
The current engine is junk as it suffers from much blow by after a heroic boost wind of 18PSI. It still runs fine but breathes heavily on anything higher than 5psi boost so it is a perfect candidate as a test mule and its simple set up makes for easy implementation of a fledgling EMS.
I must thank those involved in procuring the TA card for me and to Fred for having confidence that id actually do something with it.
let the ecu construction begin!!
Daniel.
Reason: Add comments thread link.
em_knaps
Re: Turbo'd Slaters TA build.
Post by em_knaps »
"Some" progress......
sure, the size of it is overkill but it makes it so easy to work on and as its a back yard build I feel
the more awkward and gangly it looks, the better.....
the H1 will have a ribbon cable connecting it to the TA cad but ill just use jumper wire on the H2 as the pin usage is minimal so a 50pin ribbon cable would just be pointless.
ok meow, its time for sleepies
em_knaps
Post by em_knaps »
Im sweating like the proverbial after mucking about all day in my shed that turns into a sauna in the summer,
BUT......
my slater runs!!!
fred you bastard IT RUNS!!!!!
#edit,
vids to follow, but much to some ppl's disgust i am off to a bbq, seeing it is the summer and all you know.
em_knaps
Post by em_knaps »
Well after struggling with a serious lack of motivation i decided to take some pic and the TA build as it sits in my Citroen.
I need to find a housing of some description to that the wires dont get tugged upon and things cant short out the bottom of the board.
AND, finish the heat sinking of the fets and regs...
I also need to coble some sort of connection from the turbo to the throttle body where the lame water to air intercooler used to be.
then I can drive it to the classic car and hotrod show in a few weeks....
oh, and run boost...... yay!
em_knaps
Post by em_knaps »
well it has been a while, so I thought I'd update this thread...
this TA based ECU has now run my volvo engine and now sports 5 ign outputs and 4 injection outputs.
It's a MESS!!!!
its hacky, its messy, its badly set out, I guess its a bit like the human brain... old shit remains with new shit as new shit is needed. actually I thnk the human brain is more hacky.
old dogs die hard and it will be running another engine soon.
em_knaps wrote:old dogs die hard and it will be running another engine soon.
But not quite yet! Sorry about that. I'll look into fixing this for you (and a number of others) fairly soon as it's of pretty high importance and is long overdue.
em_knaps
Post by em_knaps »
Id like to see some of the vids from today, especially the ones where your giggling when I give you the fingers during the non starting engine...
most amusing.
