Page 1 of 1
[ 1 post ] |
1989 Chev K1500, splicing in a GM 12200411.
Author |
Message |
dfarr67
Hi have most of the parts to run a 24X 411 on a SBC gen1 OBD1, looking for advances in ignition control with coil per cylinder. If I done more research I may have gone a different way- but the hole is deep now;)
- existing 7747 style DynamicEFI EBL Flash- pretty much a standalone, truck was converted from TBI to port TPI- batch. - 700r4- this is giving me an application problem.
Installed EFI Connection's 24X reluctor and timing cover, have all major parts. BUT the 411 won't control older style lockup and I really don't want to spend for a 4L60E as the 700r4 has all the good parts.
- leave 700r4 as is, it is well built and so far reliable. - leave 7747 as is - share TPS, MAP between 7747/411, 7747 to control converter lock up (not ideal sharing sensors, I know- a second MAP could be added) - cruise, leave with 7747 - iac to 411 - ac control to 411 (iac/e fans) - temp to 411 - e fans to 411 - tach from 411 - oil pres senor to 411? - PRND trans status? Needed? - can 411 log WB O2? - send out drive line ebrake disk and machine to tone wheel (40 tooth)
What's your thoughts?
Mon Dec 19, 2016 8:02 pm |
Page 1 of 1
[ 1 post ] |
Who is online |
