Author |
Message |
russian
Joined: Fri Feb 01, 2013 4:18 pm Posts: 147 Location: Jersey City, USA
I've been playing with this for some time and finally I have at least something I am not embarrassed to share. So, my idea is that modern MCUs are fast enough so that a relatively high-level programming would be possible. stm32f4discovery gives me 168MHz for about $15, http://www.chibios.org was the first RTOS I've stumbled upon - this hides most of the lower-level hardware control and even gives me threads. To begin, at first I was trying to control only fuel or only ignition (with stock ECU controlling the other piece of the puzzle), but soon enough I've realized that I should also control the idle air valve. Crank signal and MAF voltage are currently my only two inputs and I've extracted the fuel map from the stock ECU. So, currently I control fuel injection and idle. Stock ECU does ignition. This thing starts and I can set idle RPM programmatically.There is still a bug somewhere because things are not super smooth if I push the throttle pedal rapidly, but still  Here it is: https://sourceforge.net/projects/rusefi/And here is this thing in action: http://www.youtube.com/watch?v=GcxLY697WwMPS: is there a way to embed video here?
Wed Jun 19, 2013 1:30 am |
Bangbug
Joined: Fri Jan 14, 2011 11:03 pm Posts: 74 Location: Auckland New Zealand
 Congrats. Probably not super smooth as MAF lags what's actually going on. Actually ignore me, I just want to contribute and I don't know what else to put apart from smiley faces and congratulations  Thanks for the video!!!
Wed Jun 19, 2013 1:35 am |
russian
Bangbug wrote: Probably not super smooth as MAF lags what's actually going on.
Actually ignore me, I just want to contribute and I don't know what else ... There is something you can do - you can "like" the video! The stock ECU is way smoother with the same set of inputs (I've disconnected all the other wires) so it's something either with my logic or my implementation. I kinda have an idea where to look...
Wed Jun 19, 2013 2:21 am |
crazyafrican
Joined: Fri May 10, 2013 5:43 am Posts: 24 Location: Auckland, New Zealand
Awesome! Could you put up your schematics please? I might just order a board now they are so cheap haha You have no acceleration enrichment implemented yet which could be why it is not so smooth when you push the throttle pedal rapidly. Count me in for further testing
Wed Jun 19, 2013 12:20 pm |
russian
crazyafrican wrote: Could you put up your schematics please? There is not much of schematics - for instance, crank sensor is connected right to the board with just a capacitor to reduce the noises The driver circuits were fun to figure out, they now look like that https://www.circuitlab.com/circuit/8mpj ... /1024x768/
Wed Jun 19, 2013 1:15 pm |
russian
It was a bug in my code - in case of a long enough injection I was trying to schedule it in the past, and it was not really working well. Anyway, this is fixed now. I have also re-enabled ignition code and it actually does start & run with me controlling both injection and ignition.
I guess now I need to implement sequential injection.
Thu Jun 20, 2013 4:00 am |
Joined: Tue Jan 15, 2008 2:31 pm Posts: 15071 Location: Home sweet home!
russian wrote: I guess now I need to implement sequential injection. What were you doing before?
Thu Jun 20, 2013 10:59 am |
russian
Fred wrote: What were you doing before? I do not have a toothed wheel, my primary crankshaft sensor does not give me CID info, so I was squirting all injectors at the same time. This also simplifies the schematic you know  ] I will now solder three more channels and start handling the other crankshaft signal, which seems to be not really available while cranking but it does contain CID.
Thu Jun 20, 2013 12:41 pm |
What is a "CID" ? Cylinder ID?
What are the two patterns, exactly?
Thu Jun 20, 2013 1:34 pm |
russian
yes, Cylinder ID
There are three wires actually, no idea why so many. First one is the one I am currently using: (hopefully pseudo-graphics would be digestible) XXXX___XXXX___XXXX___XXXX___ (so that's say 60% duty cycle, four equal waves per shaft revolution)
Another one is more or less _X_X____X_X____X_X____X_X___ (four series of two short waves)
and the third one, the only one where one of the cylinders looks differently: _X_X_X__X_X____X_X_____X_X__ So in this one one quarter has three waves and the other three have two. I will need to recognize this special 9th wave as cylinder ID signal.
Thu Jun 20, 2013 1:49 pm |
