View unanswered posts | View active topics It is currently Thu Dec 13, 2018 12:09 am
Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
Impregacy's 1985 Toyota Hilux 22R
Hello thought I would post something to the user's rides section. I'm a user in the capacity that I selfishly use the community here for great information, but hope to contribute one day.
I plan to freeEms the carburated dizzy engine on my 1985 Toyota pickup.
But this is the current condition, so I'm staying inside building a USBDM
USBDM, my first ever hand etch, and first ever SMD soldering. BTW Thank you DueceEFI.
edit fixed a pic
Wed Jan 29, 2014 3:21 pm
Neat, good on you for DIYing it! :-)
As for your 22R, how do you plan to set it up? Crank wheel? Dizzy mods? COP? Wasted spark? Dizzy?
Wed Jan 29, 2014 11:56 pm
Well I think first and foremost we need to loose the distributor. I'm thinking the logic level GM LS1 COPs, since I hear they are good and I have some laying around. For crank position I'm open to suggestions. If the decoder for 36-1 is stable to like 6000 rpm, I was thinking it would be smart to buy one of those wheels from diy autotune. I have a Ford VR sensor I could use with it. Beyond this I would only need a MAP sensor correct?
Later I might acquire a 22RE intake manifold and add batch injection.
Thu Jan 30, 2014 5:12 pm
LS coils are good, and mostly, they're convenient. With a crank wheel you will be firing them twice as often as normal, but that's OK too. I'd still recommend a robust driver to push 5V out to them, in the style of Jaguar/RavAGE.
Beware of DIYAutoTune wheels, some of them are SHIT. Also, the wheel you use should match your VR sensor tooth size wise.
Sensor wise, you need:
RPM, MAP, IAT, CHT, and you'll definitely want TPS and WB02
For ignition only you can get away with RPM + MAP as I currently do on the hotel.
+1 to the staged approach, ignition first, fuel injection later. By batch I hope you mean semi-sequential.
Thu Jan 30, 2014 10:24 pm
Is that the 4Y 2.2 motor?
Fri Jan 31, 2014 7:35 am
Thank you Fred. Yes I was thinking to try MAP + RPM to do ignition. What would you recommend in terms of toothed wheel and sensor combo?
Ancient, this truck has the 22R http://en.wikipedia.org/wiki/Toyota_R_engine#22R
Well in a moment of true genious I soldered the USB connector onto the wrong side of my USBDM (backwards). Plugged it in and it shut down my computer. Computer rebooted OK :oops: Does anyone know for sure if the IC's were fried by this?
Sat Feb 01, 2014 1:51 am
No particular recommendations, but you should match the dimensions of the original. Gutted about the BDM, I have no idea if it's fried or not. Good luck!
Sat Feb 01, 2014 7:40 am
Looks like the BDM may be okay. Soldered a USB connector on the right way and the eee picks up something freescale.
I guess the next step is to prepare a win32 machine to load initial stuff to the BDM.
Should I start with the Jaguar 0.6 board as the basis? I thnk I am ready to build a FreeEMS, and I have a little free time at the moment!
Tue Feb 04, 2014 10:49 pm
Good news on the BDM! I would use Linux to do the loading via BDM. It's been reliable for me once I got it working at all. On the EEE I have a script to make it work. It adjusts the virtual view port so the window is created big enough. Otherwise you can't get to the buttons on the thing...
What is your intention re hardware? Print an existing design? TA + circuits? Do your own design? I can advise after I know what you are intending to do.
Wed Feb 05, 2014 12:21 am
Hooray! More utes :)
Are those prelude seats?
(Oh and everything else is also cool)
Wed Feb 05, 2014 1:49 am
