XJ6 convert to AJ16 (Need Help)
superlemon
TO92 - Vaguely active
Post by superlemon »
Hi, I am going to convert XJ6 to AJ16 since i got the engine.
However I am not sure what else I need in order to make it possible,
pls kindly let me know whether I need the following,
1) ECU (XJ6) can be tuned to AJ16 or I need to change to AJ16 ECU
2) TCU(XJ6) compactible with AJ16 engine?
3) other hardware compactible? since I was told that AJ16 same engine mounting with XJ6.
4) any security sysstem i need to get rid of?
5) who in USA can help me to Tune if I were to send the XJ6 ECU to them.
6) Can I use Emanage to tune the car?
thanks for sharing.
ray
Re: XJ6 convert to AJ16 (Need Help)
I think there may be some misunderstanding here, however I'm going to take advantage of it! :-)
We've not yet had a Jaguar running on FreeEMS, let alone a late model one, and would be honoured if you'd be the first :-D
More seriously, though, you're asking these questions in entirely the wrong place for your goals, I suspect.
