When you say all the configuration has to be done with code do you mean things like using components such as the standard Volvo coolant temp sensor? If so, taking that example, would I just use something like freetherm, write something in C, compile, burn to the chip with the BDM? If not, and I get the Jaguar kit with the SMD already soldered will I need a BDM at all?
I'm right in thinking that with the Jaguar I wouldn't need the jbperf peak and hold injector driver board aren't I?
Once I've completed the standard soldering and the optical resistors, I'll be towards the edge of my comfort zone, or at least what I understand so far of what the build requires. I read the build guide and I'm sure if I saw the software and hardware you were all talking about I would have a decent idea of what was going on. But I'm still a little concerned that I might not be able to do enough myself. I stopped reading a couple of times to learn how to implement pull up resistors and voltage dividers, if I communicate in circuit diagrams do you think this could work? I am pretty pumped about this
