Utility to convert EMStudio json tables to FreeEMS firmware
A place for small project requests from the team to exist and grow into something fully fledged and useful to the masses.
AiToR51
Post by AiToR51 »
This is an utility made in JAVA used to convert from json EMStudio exported tables to FreeEMS firmware .h files style.
CLI app.
-version 0.1 (first release):
- support for 3D Tables: VE, Lambda and Timing.
- tested with EMStudio StableTwo-84-gad3fd6e
-version 0.2:
- CLI option to don't use decimals (truncated)
-version 0.5:
- adapt output to Fred standard (download/file.php?id=1475)
-version 0.6:
- added new CLI option to see metaInfo of the json file loaded (download/file.php?id=1491)
SRC:
https://github.com/AiToR51/tableConvert ... io-freeems
use:
java -jar tableConverter(...).jar input.json [-noDecimals]
or
java -jar tableConverter(...).jar input.json [-noDecimals] > outputFile
screenshot:
if anybody founds some errors or want new features, tell me. (or fix it :P as is open source)
tableConverter-0.3-jar-with-dependencies.jar
(26.16 KiB) Downloaded 1866 times
tableConverter-0.1-SNAPSHOT-jar-with-dependencies.jar
(25.54 KiB) Downloaded 1893 times
tableConverter-0.2-jar-with-dependencies.jar
(26.07 KiB) Downloaded 1846 times
Sierra XR4i 2.0T
Re: Utility to convert EMStudio json tables to FreeEMS firmw
Very nice work! Code is pretty easy to follow. Nice implementation choices. My main comment: axle no es correcto, tio, usar "axis" en su lugar.
AiToR51
Post by AiToR51 »
perfect, I've changed it on last commit. Nothing more changed so no generated jar.
Sierra XR4i 2.0T
BTW, it's OK because this project is TINY, but you should NEVER check jars into SCM.
AiToR51
Post by AiToR51 »
new version (0.5) added
new version (0.6) added.
tableConverter-0.6-jar-with-dependencies.jar
(27.97 KiB) Downloaded 2218 times
tableConverter-0.5-jar-with-dependencies.jar
(26.67 KiB) Downloaded 2227 times
Sierra XR4i 2.0T
A few tweaks from me, and bump to 0.7, attached.
tableConverter-0.7-jar-with-dependencies.jar
(27.66 KiB) Downloaded 1832 times
