I'm the owner of a RB25DET R33 GTST and this will be my thread for doing out details of signals and whatnot, I'm in the process of designing a TA-based 6 cyl board to control it eventually, but it'll be a fairly slow process, so we'll see how we do.
Starting with what I captured on the scope tonight attached.
CAS is a Nissan/Mitsu 360 degree unit, signals as the ECU reads them are 0-5v logic. IIRC this sensor is an open collector type, so needs a pullup on these lines. (Related FreeEMS decoder thread: viewtopic.php?f=56&t=71 )
AAC/Idle valve is a 12v in, when you're on the throttle, it runs it at 50% duty, and decreases to about 20-25% as it gets to idle, the capture is with engine warm at idle.
