I just removed everyone back to reporter for blanket privileges. Clearly you'll not be able to do what you need to anymore, so whinge to me when that's a problem and I'll give you fine-grained permission to do what you need to. This is necessary due to a limitation in the UI of mantis. Apologies for the inconvenience.
Whinge here if you like, or via IRC/email/whatever.
Issue Tracker Privileges Revoked
Re: Issue Tracker Privileges Revoked
I assume I'll need some permissions back.
Assume nothing, it wastes my time, check it. Some people were setup correctly before.
Checked, and all seems good. Will let you know if that is not the case once I start using it again in earnest soon.
Just added you to EMStudio as updater after request from Mike, too. Lemme know what else :-)
if not logged in, one cannot see any issues on the tracker at all
even when logged in, I can only see issues I have raised. I can't see any other issues at all from any section/project.
EDIT: added snapshot
Total fail. Should be fixed now. Please confirm it operates as you expect. Thanks for reporting these issues issues.
fixed, in both cases! All Good now!
Thanks mate! Appreciate your efforts! :-)
