(Warning, most of these images are in the 1.5-2.0meg range)
The other day, I got a very special package in the mail:
Inside was a little anti-static bag...
My very own Jaguar A3!!! (Serial #3)
So I sat down with my trusty soldering iron, and got started. First, the 5v CPU power supply
Then the 5v analog input power supply
Both of them finished, all nice and pretty.
Now it was time for the Battery Reference Voltage circuit
Next was the MAP circuit
You can see I had a slight issue with the alignment of the MAP sensor, I'll be desoldering it later to fix that by bending the pins out slightly.
It's starting to come together!
At this point, I ran out of solder. I was very sad for a little while, but then while I was at an auction with my father, he mentioned he had some. And so I continued! More on this in the next post (after my images finish uploading)
