Low Side Driver with a MCZ33800
Peter
Post by Peter »
This is my first attempt at KiCad, and for the most part wiring schematics in general. Feel free to point and laugh at mistakes. I also couldn't figure out how to export it to a pdf properly, but I didn't try very hard, because I'm tired of looking at this monitor. I feel like I may have used an excessive number of capacitors and resistors for for lite filtering and circuit protection.
Pg 10 of this pdf was what I was going to "copy". https://code.google.com/p/open5xxxecu/d ... &can=2&q=/
I don't understand the diodes on pins 24, and 28. If anybody can explain those to me. I feel like they might be facing the wrong direction. Keep in mind that I don't understand what makes a schottky diodes special.
Peter
lowSideDriver.zip
(8.8 KiB) Downloaded 1039 times
:-p
Re: Low Side Driver with a MCZ33800
A typical mess by that author. They're like normal, but lower v drop and a few other things. It depends what CCD*_REC pins do, I guess. Will take a look at your zip tomorrow.
Peter
Post by Peter »
Don't worry about it too much. I'm mostly looking for general feedback on my "style?". Most of the values are completely arbitrary. I put them there as place holders for the possibility of needing high or low pass filters. If I was really ambitious I'd set a bunch of them up with the availability of band pass filtering. Just for fun if nothing else.
Peter
:-p
If you want hints on kicad style, look at hotcat's work and Andy's work on jag, both of those are decent. Hotcat's follows the style of ravage, but in kicad. I can't recall if andy did that too, or not.
Peter
Post by Peter »
Not so much KiCad style as circuit style. You'll know what I mean when you take a gander at the zip file compared to Jared's schematic.
:-p
/me may have forgotten about this...
/me opens zip and kicad...
Peter
Post by Peter »
No worries. I think the MCZ33800 might not be in your library since I had to draw it. It's nothing special, just a box with labeled pins.
:-p
OK, the traces remind me of the labyrinth, but if that's what you've gotta do, that's what you've gotta do. I wonder if it'd be better done in the same style that ravage and hotcat do the cpu? IE, pump everything into a bus and put each group on its own page? The top third looks normal/good. The bottom 2/3 is a bit too dense for my tastes. You also didn't include the symbols etc, so I get blank ICs and ?? thingies. Disclaimer: /me has had a few wines.
You posted, hitting submit again with only this sentence added.
