http://www.e30tech.com/forum/showpost.p ... ostcount=2
and... My poor hackles - all raised now! No one likes to see "injector pulse time" for anything - people who swap injectors regularly (or perhaps have dual fuel rails, etc) have to constantly make changes in their head - let alone account for things like battery voltage, fuel temp, and a hundred other things an intelligent system could take into account.
As an aside, 500 cc injectors on a 1 ms pulse deliver 8 ul (micro-liters, or 0.008 cc's) of fuel.
Back to cold starts:
Fred pointed out that while enrichening or IAC'ing up for a preset number of CYCLES makes the most sense (roughly the amount of heat generated is dependent on the number of rotations - though of course one could get carried away and use something like amount of fuel consumed and factor in the time spent rotating for the heat to soak etc) the simple matter is no one wants to think in terms of cycles.
Perhaps, then, a good compromise is to list it in terms of idle-equivalent time: Number of cycles which would happen during 10 seconds of standard idle (which will likely be 6 seconds of elevated idle and taper).
I suppose I've always liked the idea of actually having a cold-idle/after-start idle target - then time is appropriate. So perhaps this whole idea is a bit useless.
What do you all think?
